Chris NottSky Insurance
Results 1 to 8 of 8
    Sep 2012
    45
    2.5 tdi v6 Quattro avant water temp sensor.
    Could anyone advise where to get a new sensor for my motor. It looks like it has a green cap on the end of it. Is it a straight forward job to replace it?
    Thankyou.
    myth's Avatar
    Dec 2012
    121
    From any auto shop?!
    Yes, it's very straight forward. If you do this job when engine is cold, just unplug the connector, take the clip out and pull the sensor. If you it when engine is hot, just uncap the expansion cap (to release the pressure) and put it back on and then do as instructed above.
    Sep 2012
    45
    Jul 2007
    London
    3,241
    Get a new seal as well. I would only fit a genuine CTS, cheaper ones does not seem to last...I do suspect the thermostat is blocked'stuck open though, not a easy job to sort on the good old v6 engine...
    FOR SALE:
    Sep 2012
    45
    How would I know if it is blocked and stuck open?
    Sep 2012
    45
    Will I lose any coolant while replacing this part?
    Sep 2012
    45
    Quote Originally Posted by adamss24 View Post
    Hi there again, new sensor fitted, coolant topped up, took it out for a run and temperature steady at 90 which is Center on my display needle. Can I assume this is all ok? Does this mean my thermostat is ok and not stuck open?
    Cheers.
    myth's Avatar
    Dec 2012
    121
    Your assumption is correct.
  1. 2.5 TDi Quattro Oil & Water Temp reading - Possible thermostat prob.
    By fishr in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 3rd December 2012, 13:26
  2. A6 2.5 tdi avant Quattro c5 water temp
    By Keggers in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 26th November 2012, 19:28
  3. A4 avant 1.9Tdi or 2.5 TDi SPORT QUATTRO AVANT
    By gaffer80 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 10th January 2012, 22:49
  4. DPF removal on Audi A4 (B7) 2.0 Tdi 170 Quattro Avant
    By Holywood in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 3rd July 2010, 19:14
  5. B7 3.0 TDI Tip Quattro Avant Pro's & Cons???
    By NHN in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 15th May 2008, 20:55
