AH FabricationsSky Insurance
    myth's Avatar
    Dec 2012
    86
    2.5tdi exhaust whistle noise
    I have a 2.5tdi AFB engine for over a year now, but I have some problems I can't solve for weeks now.
    One of the older problem is that I always have the 00550 fault code. I have checked the timing, air in the fuel but everything seems fine. It doesn't bother me much since the engine performs great. Until few weeks ago.
    Some weeks ago I filled my tank with some diesel from a dubious fuel station. From that on, my problems started. Or so I think. The next day was a colder day(around 10 degrees Celsius) and the engine started with a lot of white smoke and wouldn't rev up over 2000 rpm. As the engine warms up, it would rev higher and higher: 2400, 2600, 3200 rpm...
    I have drained the tank and filled with winter diesel from a trusted source, but I couldn't get ALL the diesel out, so with the new "mixed" diesel, the engine was performing sometimes bad, sometimes very good. I couldn't find any pattern, didn't matter if the engine was warm or not. When it was performing bad, under heavy acceleration was barely moving and by 3200 rpm it would put a big white smoke after me. When it was performing very good, it can rev up to 4000 and everything was fine.
    I have filled with diesel just from that gas station and now 90% of the time it performs well. Now it can't be because of the diesel, since that is burned already. What bothers me is that I can't find a pattern when it goes bad. I can start off a red light and can't rev up over 3200 plus a big white smoke, and at the next light I can start with the engine performing great.
    Since I have had that dubious diesel, I have noticed a whistle at the back of the exhaust past 2500rpm, which is proportionate with the power needed/delivered. But again, with no known pattern. I can drive 5 miles without the whistle and then the next 20 miles with the whistle. The whistle doesn't seems to affect the performance at all! And it doesn't matter if the engine can rev or not over 3200 with or without the big white smoke.
    For the last year I have ran with the EGR off. My first thought is that the catalyst was clogged so I replugged the EGR. It didn't seem to affect any performance at all. Again, the whistle is intermittent. To be more precise, the whistle sounds like something is clogged and it is forced out under heavy loads. But if it was the catalyst clogged, the whistle would be permanent, right?
    Sorry for the long post, but I have a feeling that the experience with bad diesel has something to do with it. Also, I thank everyone who had the patience to read the entire post.
    Mar 2012
    221
    Bad diesel will normally mean muck, water and worst case some home brewed mixers like silicone. If your pretty sure change the fuel filter and the valve on top. Then run a cleaner fluid through it. 50ml of 2 stroke oil to a tank of fuel may also help it it's water. Apart from clogging the filter this can block the injectors and rust/seize the pump advance valve gear.
    AlexGSi2000's Avatar
    Feb 2012
    Liverpool
    1,068
    I would also check the turbo / intercooler pipework. This can often cause lots of white smoke if there is a boost leak.
    Check all vac lines around the engine also - maybe have a check done via VCDS aswell.
    myth's Avatar
    Dec 2012
    86
    @Alex, I have check visually the intake manifold and pipework, but I'm skeptical since the problem is intermittent. If a hose was broken, the problem would be permanent, right? The VCDS only found the 00550 fault code.
    @Typhoon, I have put 50-100ml of 2T oil into 12 liters of diesel and the problem seems to be solved. I still have some problems, but at 3200 rpm it never puts the big white smoke behind me.
  1. belt squeak at start up, then quiet whistling noise?
    By rick the spud in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th July 2007, 21:58
  2. whistling noise?
    By imported_cd8 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th April 2006, 13:03
  3. Exhaust Note/Noise
    By imported_micko2602 in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th September 2004, 19:43
  4. A6 2.5tdi - weird whistle!
    By ALTSEL in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 4th April 2004, 19:45
  5. S4 Avant exhaust/turbo noise
    By Dave1 in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th October 2003, 21:56
