Badger5Chris Nott
    May 2010
    224
    How do you replace the rear fog light ( estate)
    Hey guys
    Trying to replace my rear fog light and boot red light. However I cannot get at it. I have looked online and seen I have to remove the rear trim. I removed the triangle and the screw from inside the pull down handle on the felted trim. However that's as far as I can get. I cannot see any screws inside of where the triangle is held, andIf I yank any harder at the trim i'm going to break it. There must be something I'm missing here.
    any help would be fantastic!
    regards
    Mar 2012
    244
    May 2010
    224
    How do I remove that screw hidden in the triangle bit? Not like any screw I have ever seen. Guessing a Philips head isn't gonna cut it. Needle nose plyers?
    Mar 2012
    244
    Is this going to help...
  1. How do you remove the rear wiper blade
    By gizmo666 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th March 2011, 09:41
  2. How do you remove the rear, side window??
    By Mudz in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th December 2010, 22:14
  3. How do you remove the rear vanity light plastic cover in the back of the A3
    By drfeelgood in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th October 2010, 18:48
  4. How do you remove the rear bumper?
    By ru4shaw in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th November 2009, 10:52
  5. How do I replace the rear window brakelight bulbs? (Saloon)
    By jonnycraig in forum A4/S4 forum(B5 Chassis)
    Last Post: 5th July 2009, 23:17
