Results 1 to 13 of 13
    Dec 2010
    Wellington, Somerset
    100
    2.5tdi V6 2004 Allroad
    I believe my EGR valve has got stuck open. I have just blanked it off and the smoking has stopped so assume thats the problem. Is there any harm leaving it blanked? Coolant seems to be slighlty cooler (85 degrees, not 90) now its blanked. Or should I replace the EGR valve and have the car as its supposed to be?
    Jun 2013
    35
    Allard EGR delete kit. Find one on ebay. You will find improved economy and throttle response. Its a bit of a no brainer as you remove/bypass alot of the problematic gubbins that can eventually cause you problems - (like the EGR valve as you have stated)
    Hope this helps, I believe they are about £60.
    wesmaster's Avatar
    Apr 2012
    Oxfordshire
    275
    £60? I paid £5 posted, 2 plates, one for exhaust manifold and one for inlet pipe, 2 gaskets job done. Remove/block vacuum hose to EGR actuator.
    wesmaster's Avatar
    Apr 2012
    Oxfordshire
    275
    By the way, ive got a complete EGR for sale for the 2.5 v6 tdi. £30 posted
    Dec 2010
    100
    any idea what size hole to drill in blanking plate to stop the engine light coming on and does this work?
    Is the EGR valve you have to sell new or used?
    wesmaster's Avatar
    Apr 2012
    Oxfordshire
    275
    I have removed the whole EGR system, didn't need to drill holes, I mapped the egr out anyway so no issue with eml.
    The EGR is used but good condition, just not needed.
    To see if it put EML on, remove vacuum hose and put a screw in the hose, drive car see if light comes on!
    Jun 2013
    35
    Wesmaster care to share the link for where you got a kit for £5 from? Never heard of one that cheap.
    Jul 2007
    London
    3,079
    Quote Originally Posted by bullawayo View Post
    Allard does not do a EGR delete kit for the 2.5 tdi so you either block the holes with the blanking plates or just pull the vacuum pipe and block it with a bolt or just have it mapped out in the tune ! Wes, there's no need to plug the pipe if yours is deleted in the map !
    FOR SALE:
    wesmaster's Avatar
    Apr 2012
    Oxfordshire
    275
    Quote Originally Posted by adamss24 View Post
    Here is a link ebay for a pair of blanking plates, with the EGR completly removed there is loads more room in V and looks tidier.
    I only plugged hose to prevent dirt ingress
    Jul 2007
    London
    3,079
    Ok i get it now, sorry- my bad !
    FOR SALE:
    Jan 2012
    teeside
    45
    I fitted a blanking plate to my egr around 14months ago. It has given no problems in fact id say pulls better now. Had twi mots since and never failed for emissions.
    Oct 2011
    SWEDEN
    Question
    Quote Originally Posted by wesmaster View Post
    I mapped the EGR out anyway so no issue with eml.
    Allard does not do a EGR delete kit for the V6 2.5 TDI
    Who erase the EGR when mapping ?
    wesmaster's Avatar
    Apr 2012
    Oxfordshire
    275
    I asked specifically for egr delete after a lengthy discussion with my file writer, took 3 attempts to get it right, but good results.
  1. Tiptronic display PRNDS blanking out (Allroad 2.5TDI, 2004)
    By ms1083 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 2nd January 2012, 19:11
  2. Allroad 2.5TDI 2004 Gearbox/front diff problem
    Last Post: 28th September 2011, 16:37
  3. Questions with my A4 Avant 2.5tdi Quattro - 2004
    By vinesh in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 19th June 2010, 22:16
  4. help!!!advice needed cambelt jumped off 2.5tdi v6 2004 cabriolet
    By davidfox280585 in forum General Automotive Chat
    Last Post: 4th December 2009, 06:54
  5. Allroad 2002 2.5tdi Questions
    By Biggles in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 5th December 2006, 07:02
