Chris NottBadger5
    Jul 2011
    50
    Noise in transmission and movement in manual gear stick advise needed
    Drove my wife's 2004 Allroad diesel last week and noticed a clunk from the transmission when pulling out of a junction, seemed to be from the back of the car.
    Also whilst going down a hill I lifted off the throttle with my hand on the gear stick, with the car in fourth gear the gear stick gave three to four back / forward motions ?
    Its just turned 79000 miles
    Any ideas on what this could be.
    also the airbag light is constantly on, any checks I can make prior to going to a dealer.
    May 2012
    RETFORD, NOTTS
    1,753
    Dont go to the dealer if somebody local has vcds and willing to plug it in! This will tell you the fault with the airbag and possibly reset the light.
    The clunk, maybe the bottom engine mount? look under the bonnet when the car is started and stopped and see what movement there is?
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    Jul 2011
    50
    Thanks for that much appreciated
    BargeFamilia
    Jun 2013
    Wokingham, Berkshire
    53
    Add bullawayo on Facebook Visit bullawayo's Instagram Channel
    Seconded on the gearbox mount. I would recommend an uprated polybush item - maybe powerflex - makes a huge difference to stiffening up the whole transmission
  1. Manual gear box creaks in 4th & 6th!
    By funkycat in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 12th July 2009, 17:09
  2. Noise when stationary and I press the Clutch
    By imported_Smudge973 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 7th October 2004, 20:09
  3. Rattleing noise from left and back of car
    By pwnorman in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th February 2004, 21:06
  4. Nocking noise from left and rear of car
    Last Post: 10th February 2004, 20:59
  5. Engine Noise in 4th and 5th
    By BiffS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th October 2003, 08:41
