Results 1 to 9 of 9
Thread: A/C problem
    Jul 2013
    A/C problem
    There is a problem with my audi a6 A/C. There is no cool air, just hot air..
    ECON light is always ON, even I filled a month ago with refrigerant. Also when I try to start A/C the noise of vehicle don't change that it used to do 2 months before, so I think the A/C fan isn't working.
    Could you please help me what should I do, and do you know where is the problem?
    PS. sorry for my bad English!!
    Thank you very much!
    wesmaster's Avatar
    Apr 2012
    Oxfordshire
    291
    Hi, did you have it regassed or just added gas?
    Jul 2013
    Quote Originally Posted by wesmaster View Post
    Hi, I think just added some gas r134a or something like that, because the technician said the pressure is under the normal. After that about 1 month it was everything okay, but now I see that ECON light is always ON and there is on cool air.
    Any idea?
    Thanks.
    wesmaster's Avatar
    Apr 2012
    Oxfordshire
    291
    Get it regassed properly and check low and high pressures. Also get checked for leaks.
    Jul 2013
    Do you mean to replace all the gas with the new one?
    Yes I think it is leaking somewhere.
    But, do you know why can't I turn OFF the ECON light never?
    Thanks in help!
    wesmaster's Avatar
    Apr 2012
    Oxfordshire
    291
    You cant turn econ off because there is a fault with the system, get it regassed properly (recovery, vacuum, vacuum hold, dye/oil added, gas injection) check pressures.
    If you suspect a leak, pressurize system with leak detection gas.
    Jul 2013
    I would like to ask something else, when I start the A/C then I see the A/C fan isn't working, is it because the pressure is not normal or maybe the fan is broken, Do you know it?
    Again Thank you very much in help!
    Apr 2013
    Aberdeenshire
    592
    Quote Originally Posted by drilir View Post
    If your system is leaking it could be that the system pressure is below the preset pressure of the low pressure switch so your compressor clutch will not come in so no discharge pressure is produced removing the need for the condenser fans to run.
    Jul 2013
    Quote Originally Posted by Chillout View Post
    Thank you very much for your help.
    Best wishes!
  1. Transmission Problems
    By MisterD in forum General Technical / How To
    Last Post: 3rd February 2003, 13:23
  2. Ooo eck I've got a problem!
    By AlexStanley in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th January 2003, 13:12
  3. Problems with alarm transmitter.
    By DJG in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th January 2003, 08:23
Tags for this Thread
