Chris NottJMB Retrofits
    Mar 2013
    24
    Cambelt fitted, strange wear, help
    I have attached a photo of my Cambelt.
    Basically fitted it 300 miles ago. Checked it and it has a strange metallic glaze on it with the same corresponding glaze top idler.
    it is a 1.9 tdi 110 afn. It's running perfect but wonder why it's wearing like this.
    Jun 2011
    Great Melton Norfolk
    1,344
    Has the idler pulley or tensioners seized
    Mar 2013
    24
    It ran fine after installation, but it would seem as if the idler has become sticky or seized
    Apr 2013
    Aberdeenshire
    590
    I wouldn't run it like that as it could go ping and cost you £££ is your coolant ok as wonder if the water pump is ok also did you use a full belt kit
    Mar 2013
    24
    Isn't the Cambelt auxiliary on this engine, it seemed it was when we checked, and yes full belt kit
    Jul 2007
    London
    3,209
    Don't worry too much, the marks are from the oil pump drive pulley and if the tensioner notches are lining up and move anticlockwise when pushing down on the belt then all is ok ! I do hope you tensioned the pulley clockwise ?
    FOR SALE:
  1. Strange noise, help???
    By Trigger in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 13th May 2009, 18:53
  2. Strange noise- Help please
    By paul_devon in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th April 2009, 09:24
  3. uneven tyre wear help!
    By Jonesy in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd April 2008, 07:39
  4. The standard factory fitted A3 alarm (HELP)
    By Vikz in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th July 2006, 19:51
  5. Fitting Dump Valve HELP!
    By Charlies604 in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th December 2005, 23:22
