Monster MotorsportBadger5
Results 1 to 7 of 7
    Oct 2011
    West Yorkshire
    67
    Help, can someone tell me what these wire connectors are for?
    Got the econ light stuck on and noticed these wires were unplugged. Can someone please i.d them? It's the two connectors under the cover next to the power steering reservoir just behind the light. Thanks!
    Oct 2012
    106
    One of them is related to the electric aux fan. Not sure which one.
    Sorry, not much but it's all i got!
    2001 A6 1.9tdi SE Avant
    Dec 2010
    Wellington, Somerset
    105
    1 of them is the AC radiator fan, the electric fan on the front of the car which you can see on the left inside side of the radiator. If it is unplugged the fan will not work and likely the AC gas will overheat, you may be ok if travelling fast but in slow traffic this would not allow enough cooling. What would happen if it overheated? - fuse blow/safety cut out/ac gas overpressure & escape somewhere? I would guess any of these would cause the AC system not to work and therefore not allow the econ button to be turned off.
    The other connector also goes to something in the front end carrier as I had to unplug both this weekend to remove the front end to do the timing belts - has something like this been done recently and forgotten to be reconnected?
    Oct 2011
    West Yorkshire
    67
    Thanks for the replies, yes I have just had the cambelt done.... Prior to this the econ light had come on due to what I suspect was low pressure. I had it regassed last night but it obviously didn't work and it had thrown up some fault codes. Hopefully with it already being off it won't have damaged anything.
    Oct 2011
    West Yorkshire
    67
    Trying to find the fuse location for the aux fan, is in in tr drivers footwell?
    Oct 2011
    West Yorkshire
    67
    Found them all, they are fine but not sure if the fault code will still be present as I don't have vag com to hand. I guess it saves the code even with the battery off?
    Dec 2010
    105
    Quote Originally Posted by OllieQS View Post
    not sure. so long as disconnecting battery does not cause issues with your radio try disconnecting it then before reconnection to the battery touch the + and - terminals together. I hear by shorting the car this way it can reset any electronic issues/fault codes etc.
  1. Can anybody tell me what these are?
    By Darylaas in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st April 2013, 20:02
  2. can anyone tell me what these abt alloys are called
    By wesser99 in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th April 2011, 19:14
  3. Can someone tell me what has gone wrong here please..
    By memmo in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st July 2010, 20:37
  4. can someone tell me what this part number comes back as.. 8PO 941 029N
    By latta1989 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th May 2010, 01:45
  5. Can anyone tell me what these fault codes are please?
    By cha1n in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd July 2006, 13:16
