Badger5Sky Insurance
    Dec 2010
    Wellington, Somerset
    105
    audi 2.5tdi V6 timing belt change issues - lack of power
    just completed doing my timing belt change. car runs smoothly, timing within spec on VCDS. Drives ok but lack of power - almost as tough turbo not working. Any help/ideas?
    Took front end completely off but sure i have reconnected everything.
    No fault codes.
    Could it be to do with the vacuum pump which has to come off to get timing tool in? What would happed if it is not making a vacuum? If this is a possible cause how do you test it?
    Dec 2010
    105
    just noticed close to the vacuum pump on its hoze there is a T connector and 1 of the tiny pipes has snapped off its nipple. THis pipe leads to a box with lots of other vacuum pipes & electricial connectors - could it really be as simple as lack of vacuum getting to the turbo?
    wesmaster's Avatar
    Apr 2012
    Oxfordshire
    291
    Yep, vacuum controls boost and egr.
  1. 2.5TDi Timing Belt Change - What Else Should I Get Done?
    By steamship in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 28th January 2013, 00:23
  2. Timing Belt change
    By enda1 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 30th October 2007, 14:19
  3. Timing belt change
    By enda1 in forum A4/S4 forum(B5 Chassis)
    Last Post: 22nd October 2007, 21:23
  4. timing belt change
    By danotto in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th July 2007, 11:42
