Badger5AH Fabrications
    Jul 2013
    Question Issues with my 2.7t
    Hello, on a drive today, i got the esp light and abs light up, and a sudden stop in acceleration. no problem to drive on, but the lights would not go away. did not do any heavy driving from there on and home. but did a vagcom as soon as i got home..
    Friday,05,July,2013,17:09:06:15770
    VCDS Version: Release 11.11.6
    Data version: 20121223
    Chassis Type: 4B - Audi A6 C5
    Scan: 01 02 03 06 08 15 16 17 18 22 34 35 36 37 45 55 56 57 65 67
    75 76 77
    Mileage: 206440km/128275miles
    Address 01: Engine Labels: 078-907-551-AZA.lbl
    Part No: 4B0 907 551 G
    Component: 2.7l V6/5VT G 0002
    Coding: 05752
    Shop #: WSC 00089
    VCID: 28544E89C8CE815848B
    1 Fault Found:
    16486 - Mass Air Flow Sensor (G70)
    P0102 - 35-00 - Signal too Low
    Readiness: 0000 0000
    Address 02: Auto Trans Labels: 01V-927-156.lbl
    Part No: 4B0 927 156 L
    Component: AG5 01V 2.7l5VT RdW 2526
    Coding: 00001
    Shop #: WSC 00000
    VCID: 3064A6E9F01EC99890B
    1 Fault Found:
    18265 - Load Signal
    P1857 - 35-00 - Error Message from ECU
    Address 03: ABS Brakes Labels: 8D0-907-389.lbl
    Part No: 8D0 907 389 E
    Component: ABS/ESP allrad D36
    Coding: 06397
    Shop #: WSC 02325
    VCID: 356A97FD0F7CECB0C3D
    1 Fault Found:
    18265 - Load Signal
    Coding: 06397
    Shop #: WSC 02325
    1 Fault Found:
    18265 - Load Signal
    erased the faults, but they come back at once.
    have done some search on the web, and found 2 thing it can be.
    1- the abs controll unit
    2- MAF
    what do you guys thing it might be?!
    tried to disconnect the maf while running, but no change in how the engine run....
    Jan 2011
    northants
    165
    check the air mass readings on your vagcom to see if in spec but would suspect maf
  1. Startup Issues with my TT
    By tt boy 2208 in forum General Technical / How To
    Last Post: 10th January 2008, 18:49
  2. multiple issues with A3 1.8T (Not S3)
    By Scrappy in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th September 2007, 15:01
  3. Any general manufacturing issues with 97/98 C5?
    By Dan Frederiksen in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 13th May 2007, 18:32
  4. Common Issue with the DIS
    By coupe-se in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th February 2007, 19:19
  5. Still Having Perfomance issues with my 2.5tdi Allroad
    By Biggles in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 23rd January 2007, 21:32
