Hello, on a drive today, i got the esp light and abs light up, and a sudden stop in acceleration. no problem to drive on, but the lights would not go away. did not do any heavy driving from there on and home. but did a vagcom as soon as i got home..
Friday,05,July,2013,17:09:06:15770
VCDS Version: Release 11.11.6
Data version: 20121223
Chassis Type: 4B - Audi A6 C5
Scan: 01 02 03 06 08 15 16 17 18 22 34 35 36 37 45 55 56 57 65 67
75 76 77
Mileage: 206440km/128275miles
Address 01: Engine Labels: 078-907-551-AZA.lbl
Part No: 4B0 907 551 G
Component: 2.7l V6/5VT G 0002
Coding: 05752
Shop #: WSC 00089
VCID: 28544E89C8CE815848B
1 Fault Found:
16486 - Mass Air Flow Sensor (G70)
P0102 - 35-00 - Signal too Low
Readiness: 0000 0000
Address 02: Auto Trans Labels: 01V-927-156.lbl
Part No: 4B0 927 156 L
Component: AG5 01V 2.7l5VT RdW 2526
Coding: 00001
Shop #: WSC 00000
VCID: 3064A6E9F01EC99890B
1 Fault Found:
18265 - Load Signal
P1857 - 35-00 - Error Message from ECU
Address 03: ABS Brakes Labels: 8D0-907-389.lbl
Part No: 8D0 907 389 E
Component: ABS/ESP allrad D36
Coding: 06397
Shop #: WSC 02325
VCID: 356A97FD0F7CECB0C3D
1 Fault Found:
18265 - Load Signal
Coding: 06397
Shop #: WSC 02325
1 Fault Found:
18265 - Load Signal
erased the faults, but they come back at once.
have done some search on the web, and found 2 thing it can be.
1- the abs controll unit
2- MAF
what do you guys thing it might be?!
tried to disconnect the maf while running, but no change in how the engine run....
75 76 77
Coding: 05752
Shop #: WSC 00089
1 Fault Found:
Coding: 00001
Shop #: WSC 00000
1 Fault Found:
18265 - Load Signal
Coding: 06397
Shop #: WSC 02325
1 Fault Found:
18265 - Load Signal
Coding: 06397
Shop #: WSC 02325
1 Fault Found:
18265 - Load Signal
2- MAF
