EM TuningSky Insurance
    Jun 2012
    Cambelt change - what parts to switch out?
    Appreciate this has probably been asked a million times before, but I need to get parts ordered ASAP as car going in next week.
    So .... 2001 2.5TDI Allroad manual. 170K miles.
    Is there anywhere that does a complete timing belt kit - belts, tensioners, water pump, seals etc? Or is geuine the only way to go?
    If someone could tell me what it is sensible to change while the front end is off, given the mileage, that would really help me out (and anywhere to get the parts from, apart from Audi UK). Generally the car is in good shape, not had any issues with the engine at all yet.
    Toby
    Chrisw4266's Avatar
    Feb 2013
    50
    The Indy that quoted for my timing belts recommend changing the water pump and tensioner. They also said they'd change the aux belts and there tensioner. They quoted me £578 for everything inc fitting and vat. Pretty good I thought.
    In a place the south forgot.
    wesmaster's Avatar
    Apr 2012
    Oxfordshire
    291
    Hi £578 incl is too cheap, I got a complete kit from ECP and a very good price (trade price) and that was still £300. I doubt they have quoted for a complete kit.
    Speak to adamss24, the v6tdi Guru!
    Chrisw4266's Avatar
    Feb 2013
    50
    Must admit I did think it was a bit cheap as the kit I priced up was £290. Mines not due for another 40k so didn't ask for a break down of what was included, just a rough price.
    Dec 2010
    Wellington, Somerset
    107
    Just completed mine yesterday.Price wise - I had asked my independent audi specialist, he said its 5 hours time labour at his is £40/hour plus vat so that's nearly £300.
    Parts to replace (or at least what I repaced). cambelt, injection pump belt, both tensioners & idlers. Water pump, thermostat, new coolant. both aux drivebelts and their tensioners & idlers. I bought all these as a kit containing all of them (minus thermostat & coolant) on ebay for just over £300. Use good quality, these were continental belts. The real audi kit is ok but does not contain the hydraulic tensioner for cambelt or the idlers,tensioners for aux belts, or the aux belts, water pump or thermostat.
    With this in mind can't see how a garage would do for less than £700 unless missing things out.
    The major bit of the job is getting access. you have to remove air housing, air hoses, header tank, vacuum pump to get to the back of the engine to fit the timing locking tools which in itself is fiddily - use a mirror. Other than taking time its not too bad until something else goes wrong or brakes!
    Other than that managed to do the job with front end in "service position" as plenty of room. ..Actually I lie - found the bolt securing the old timing belt tensioner was v stiff and when got it out found it to have ruined the screw thread in the aluminium engine casing to fix had to drill it out, tap a tread and fit helicoil. To do this needed to take front end off completely and actually didn't involve as much extra work as I expected.
    Plenty of special tools required. Timing setting kit, pullers to remove camshaft sprockets, holders to prevent you putting pressure on the timing tools when tightening sprocket bolts, 32mm open ended spanner (2 of them or 1 big adjustable & 1 spanner) to remove viscous fan, socket set including star drive & hex bolts as almost everything is hex bolts.
    Mar 2012
    244
    Don't forget the manifold gaskets, replacement cap for the cam shaft blank (should be in the kit) and I suggest a new O ring for the vacuum pump.
    While its in bits clean out the manifold and the EGR valve.
    My journey...
    Audi A6 Avant - Refurb & Repair (Pic heavy) - Page 15 - Detailing World
    Might help...
  1. What parts are needed for a Multitronic oil change
    By medicpaul in forum Parts Requests
    Last Post: 28th February 2011, 17:24
  2. cambelt replacement - what parts are required?
    By drewbee in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 8th June 2010, 22:23
  3. What parts are changed : S4 B7 variable service 2 @ 38k
    By pdt in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 14th January 2010, 19:51
  4. v6 30v cambelt and water pump change what tools?
    By dummi in forum General Technical / How To
    Last Post: 30th December 2005, 10:46
  5. Cambelt change what mileage?
    By TDI in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 5th September 2005, 08:29
