Volks AutosSky Insurance
    Ay3
    Apr 2011
    Allroad towbar fitting
    OK so I now have my Allroad and need to get a towbar fitted, I have had various quotes ranging from £360 to £560 for a 13pin electric removable system.
    My question is should i get dedicated wiring or use a relay / scotlocks to hack into the wiring. Not sure if the Allroad has any kind of stability system that "knows" when a trailer is attached and so i should therefore go for dedicated wiring?
    I am exploring other avenues but would be great if anyone here knows the answer!
    Jan 2011
    northants
    165
    theres a bloke on vwaudi forum that specialises in towbars
    Jul 2007
    London
    3,076
    You should have gone for a factory fitted towbar as it does so much more ! ESP, suspension, brake bias all are influenced when you plug that tow lead in !
    FOR SALE:
  1. A6 Towbar Fitting?
    By Ligur in forum A6/S6/Allroad forum (C6 Chassis)
    Last Post: 4th April 2012, 17:55
  2. Will the B8 Allroad grille fit a regular avant front end?
    By allroadstomtl in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 27th September 2011, 02:44
  3. Towbar Fitting
    By stevereid in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 19th March 2010, 21:51
  4. towbar fitting
    By gav in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th May 2009, 16:42
  5. A4/S4 TOWBAR FITTING
    By S4_dan in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th August 2006, 09:39
