Volks AutosChris Nott
Thread: Vag com?
    BillyV6's Avatar
    Jun 2013
    Ashford Kent
    27
    Vag com?
    As above, I understand it as a scanning program you install on a laptop so you can remove codes Etc? Is this correct?
    What I want to know is,
    Does it cost anything?
    Where do I get the cable from?
    Do I need to get a genuine rosstech cable? Or do eBay ones work?
    Cheers all.
    May 2012
    RETFORD, NOTTS
    1,753
    Have a read through vcds forum section, pm nhn for prices :D
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
  1. Logging turbo boost with VAG-COM
    By Ram in forum VCDS (formerly VAG-COM) forum
    Last Post: 26th January 2009, 22:23
  2. PDA version of VAG-Com....VAG-Check
    By Gambba in forum VCDS (formerly VAG-COM) forum
    Last Post: 14th January 2009, 09:09
  3. Help needed - Vag-com owners/experts?
    By tim99 in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th May 2004, 18:15
  4. obd vag com reset device
    By dann959 in forum A4/S4 forum(B5 Chassis)
    Last Post: 16th April 2004, 08:15
  5. Vag-Com Tunning for the Audi TDI
    By Pookie in forum Tuning
    Last Post: 29th July 2003, 21:13
