EM TuningBadger5
    Aug 2012
    Please help with advice or feedback......
    So I'm driving down the interstate here in South Jersey cruising around 75 miles an hour in my 2008 A6. All of a sudden my car seems to lose power and the engine starts to shake and sputter, then cuts off. Lucky I was able to immediately work my way from the far left lane to the shoulder and out of harm's way. I have no idea how I was able to do that without being rear ended or causing an accident.
    Anyway, I had the car towed to the local Audi dealer and I just received the call from the Service Manager. They found that there was low compression and in investigating found a shattered spark plug. The spark plug was shattered by a broken valve. The engine is blown!
    The strange thing is, I did not receive any prior notice or warnings that there was a potential catastrophic problem. No check engine light. No strange noises (ticking or knocking). No previous loss of power. No nothing. The car has 48,000 miles on it and it has been serviced by this dealership almost obsessively since purchased as a CPO. Needless to say that the engine is being replaced by Audi under warranty. I'm told that they are replacing it with a new engine.
    The question that goes out to the great members of the board is what concerns should I have withan engine replacement? What should I be looking for? What cautions should I take if any?
    myth's Avatar
    Dec 2012
    120
    These kind of failures does not come with any warning. Once a valve is broken, there is no turning back.
    Regarding new engine,they should give you more information about it: is this a particular case or a fault in engine design.
    If you change the oil at specified interval, you shouldn't have any problems. Well, not anything that will blow up the engine.
  1. I've looked on the forum and can't decide yet. Please help with some advice.
    By Simon170TDI in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th February 2013, 17:40
  2. Just put deposit on this Orange S3 - please help with engine details?
    By jamieswales in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th May 2010, 16:53
  3. Replies: 5
    Last Post: 22nd April 2010, 09:48
  4. Please help with codes..airbag.
    By vw754 in forum VCDS (formerly VAG-COM) forum
    Last Post: 8th July 2008, 02:01
  5. Anyone help with advice on RS4 engine swapout?
    By doeboy in forum RS4 Forum (B5 and B7 Chassis)
    Last Post: 12th May 2007, 22:52
