Sky InsuranceChris Nott
    myth's Avatar
    Dec 2012
    117
    Radio signal too low
    I noticed that my radio (1998 A6 C5 2.5tdi) has very low radio signal, even in town. First time I checked the antenna cable to be plugged it, but it was fine. I also checked the antenna itself and looks fine to the naked eye. I took it down and the connector seem fine too.
    Does this model has any radio signal amplifier? If yes, where is located and how can I check it?
    myth's Avatar
    Dec 2012
    117
    Anyone?
    Jay a
    Jun 2013
    West Midlands
    17
    Add Jay A on Facebook
    i had this once with a none audi oem stereo where one of the wires had come off the board which maby just see if the wire or conecter is loose at all, easy fix if you are handy with a soldering iron, worth a look but prob be something else, also crosion on the areal conection
  1. Error: Voltage too Low ?
    By SilverBullet in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th April 2007, 18:28
  2. BOSE sub / aerial not picking up radio signal
    By twofivenine in forum In-Car Entertainment
    Last Post: 24th January 2007, 16:50
  3. Radio Signal Amp??
    By Beerzo in forum In-Car Entertainment
    Last Post: 13th January 2007, 21:39
  4. my low beam is aimed too low, how do i adjust???
    By imported_mack611 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 2nd August 2004, 09:25
  5. Auto levelling Zenons on S3 - too low
    By munkey in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th July 2003, 11:30
