EM TuningBadger5
    amimmortal's Avatar
    Jul 2004
    Dunfermline
    226
    Knocking from front o/s wheel
    Hi all,
    We've just returned from a 400 mile round trip to the in-laws with no problems to report. Then, this morning, on a drive up to Perth, I became aware of a noticeable knocking sound coming from the o/s front wheel (I think).
    It was most obvious at about 55mph, but could be heard clearly up to and beyond 70mph - it was noisiest when going downhill and disappeared completely when I braked. It didn't seem to make any difference if I was steering left or right at the time. It doesn't seem to be making any noise at lower speeds.
    I recently had the front discs and pads changed, and the front o/s calliper was also replaced as the old one had seized, apparently.
    The car's just turned over 69,000 miles. The o/s CV boot kit was fitted at 44,000 miles, and the n/s was done at 47,000 miles. Additionally, the n/s front lower ball joint was replaced at 51,000 miles.
    Any tips welcome!
    Cheers,
    A.
    May 2012
    RETFORD, NOTTS
    1,748
    I was about to post a thread but i have some similarities on my a3.
    i think the noise started when i swapped tyres front to back. A whoomp whoomp whoomp rotational noise from driver side wheel when doing about 30-70 mph round sweeping left bends. Not wheel bearing.
    Today i eventually finished upgrading to 312 discs n pads, the whoomp noise has gone but after about 30mph i hear a noise like something scraping at a point of the rotation. The noise changes when pressing brakes.
    Due to this i think it could be a calliper related issue. My passenger calliper looked in better condition than driver side.
    I can't understand the issue though , why would a calliper cause this noise.
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    amimmortal's Avatar
    Jul 2004
    Dunfermline
    226
    Hi all,
    Turns out the new disc is rubbing against the metal guard plate. Not sure why - could be that the discs fitted were too thick. Either way, nothing too serious.
    Garage has pledged to get it sorted for me either way.
    Cheers!
    A.
    TwistedMind's Avatar
    Long Live The A6
    Jan 2011
    115
    Metal guard plates are made from tin foil ! LOL very bendy !
    Audi A6 1.9TDI 2000
    Love the problems !
    Mar 2012
    239
    Low speed Knocking......front and rear lower control arms.... and then the upper ones.
    Lower ball joints not easy.....upper pinch bolts right cow...
    Then the engine mounts?
    amimmortal's Avatar
    Jul 2004
    Dunfermline
    226
    Hi all,
    Car now back and all noise gone. The guard just needed adjusting so hopefully that's the last of that...
    A.
  1. Knocking from front
    By scoobyra in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th October 2010, 17:03
  2. Knock from front of car
    By Oranoco in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th April 2008, 22:43
  3. knocking from front end
    By lazzaman in forum A4/S4 forum(B5 Chassis)
    Last Post: 14th July 2007, 23:54
  4. Awful knocking from front of car - ideas?
    By monkeytrousers in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th February 2007, 16:19
  5. knocking on front passenger side wheel
    By shufti in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 14th November 2006, 15:16
