you can buy some removers from ebay mate or even halfords if you need them quick .
They are only a couple of punds from ebay.
Insert the removing blades in all four corners and wait for the click then pull gentlyt and the whole unit will come out .
Type removal of audi headunit on you tube something should come up
I would also remove glovebox and push Head unit out from behind, rather than pull out on keys as you can damage clips, especially if you have extra resistance (the handsfree).
Regards
Wes
Yes, they are the slots. Get a set of these Radio removal 4 keys.Audi VW Skoda RNS-E MFD MFD2 0142 | eBay You don't need to remove the glovebox to take the nav out with the correct keys they can be removed just fine without pushing from the back.
