EM TuningVolks Autos
    audi-a6's Avatar
    Aug 2011
    christchurch
    489
    Urgent help needed!!!!
    I have an Audi a6 2.7t, had a remap about year ago, boost set to 1.2 bar........... a few weeks ago my turbos failed, so i gave the car to the sane garage who mapped it, they put on a pair of rs4 turbos and then mapped again, they have had the car for nearly 2 weeks as they keep having a problem, car keeps going into limp mode saying "boost limit exceeded they set boost to 1.3, so they said it maybe a faulty maf (the maf was dodgy anyway) so they replaced that, also found a boost leek on waste gate fixed now but car still has the same problem, they saying the new maf is faulty and thar they tried an rs4 maf and the car worked fine untill "fuel system to lean" came up. So basically they saying that a standard maf cant keep up with a pair of k04's??? i don't believe this. they saying the best way to sort this out is to put on a rs4 maf, fuel injectors and pump......... dont get me wrong, i was going to do this eventually any way, but after the cost of turbos ect... cant afford at the mo. So i just wanted some other opinions to see what you think??? car is still in garage at the moment, so need a response asap please.
    Passat B5.5 tdi....... big plans to come
    Audi A3 8p motor way work horse
    Nissan Skyline r33 gts-t ..... my mid life crisis fun car
    2,152
    If you don't get much response, try and ask this question in the A4 B5 section, as the S4 used the same engine.
    audi-a6's Avatar
    Aug 2011
    christchurch
    489
    yeah, i just did, thanks
  1. Urgent help needed!
    By imported_Gibbsy in forum In-Car Entertainment
    Last Post: 1st November 2004, 09:44
  2. URGENT - HELP NEEDED CAR IN BITS
    By S3_MCD in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th August 2004, 23:15
  3. Urgent help needed!!!!!
    By Stuart_A3_Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th February 2004, 17:03
  4. URGENT HELP NEEDED... WHAT WOULD CAUSE....
    By RichA3Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd July 2003, 07:50
  5. Urgent help needed
    Last Post: 13th July 2003, 09:02
