Chris NottSky Insurance
Thread: 2.5 v6 tdi cams
    wesmaster's Avatar
    Apr 2012
    Oxfordshire
    292
    2.5 v6 tdi cams
    Hi, probably covered before but is it all engine codes that suffer with the cams wearing?
    or just certain ones?
    Mines a AYM, a little concerned!
    Also, got an oil leak from top of engine, very difficult to see exactly where. Any common leaks?
    Thanks.
    Wesmaster
    Jul 2007
    London
    3,258
    Take the rocker covers off and look at the cams, i have had cars with over 200k with no wear on the cams and cars with 150k on long life servicing which had cams changed ! Usually is oil retention valves not keeping oil in the heads overnight and longlife intervals/poor quality oils that kill these engines, they are good with regular maintenance !
    FOR SALE:
    wesmaster's Avatar
    Apr 2012
    Oxfordshire
    292
    Thanks Chris, will look over next few days. There's no performance loss, just a slight noise from left bank to the rear.
    Sep 2012
    Quote Originally Posted by adamss24 View Post
    hi where is the oil retention valve is it easly checked/ replaced?
    Jul 2007
    London
    3,258
    There are 2 oil retention valves, under the oil filter housing buried deep under the injector pump !
    FOR SALE:
  1. A4 2001 V6 TDi Cam Lobe wear
    By leedjc in forum Diesel forum
    Last Post: 2nd May 2012, 13:19
  2. 2.5 V6 TDI cam belt cover
    By ms1083 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 28th June 2011, 06:40
  3. 2.5 TDI cams
    By A4 nut in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 18th September 2010, 21:58
  4. 2.0 TDI cam belt change
    By matbomb in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th August 2009, 16:55
  5. A6 1.9 tdi cam belt change......Help!!
    By alibob in forum Diesel forum
    Last Post: 26th February 2007, 23:31
