Sky InsuranceBadger5
    Sep 2012
    LEEDS
    125
    Cannot get rear door open?
    Hi one of the kids put the rear window down yesterday and it then refused to go up.
    Managed to open the door card and put the window up with a little assistance .
    However when i put the door card on i forgot to allow the door pin to feed through the hole in the top part of the door card .
    I now cannot open the door any ideas ?????
    Chrisw4266's Avatar
    Feb 2013
    50
    As the lock pin is stuck down behind the door panel this could be a tricky one. When you press the remote to unlock can you hear that door try to unlock ? If so try pulling the door handle as you press the remote you might be able to catch it before it locks again. If you can't hear the lock bouncing then not sure how you would get it open.
    In a place the south forgot.
    Sep 2012
    LEEDS
    125
    I managed to prise the hole part on the top of the door (where the pin feeds through GENTLY) and then pull the pin .
    And there you have it open door !
    I managed to trap it when i replaced the door card on the other day .
    Pheww !
    Chrisw4266's Avatar
    Feb 2013
    50
    Nice one glad to here you fixed it.
  1. Sportback rear door cards - how did you get them off?
    By Ash187 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd March 2012, 00:46
  2. Replies: 3
    Last Post: 11th June 2011, 14:05
  3. Left rear door won't open from outside
    By lscolman2 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 27th April 2011, 18:49
  4. cant open rear door
    By rasA4 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 10th September 2008, 10:50
  5. cant open rear door
    By rasA4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 5th August 2008, 10:03
