AH FabricationsEM Tuning
Results 1 to 8 of 8
Thread: Stuck window
    Oct 2012
    Stuck window
    My rear offside window would not fully close, I had to manually pull it up while pressing the control.
    whats that all about?
    Oct 2012
    P.S. has a new battery fitted recently and havnt touched rear windows since.
    Jun 2011
    Great Melton Norfolk
    1,348
    have you reset the windows at all? open them fully and close again.
    Oct 2012
    Done the front two but not the rear.
    Hi Delboy
    It is most probably caused by rubbish getting in the window runners. This happened to me and it actuall made my window jump out of its runners!
    My solution was to wind the windows down and spray the runners with silicone spray. Then wind the windows up and down for a few mins before trying to wind them all the way up. Haven't had a problem since and that was 2 years ago.
    Hope this helps
    Rob
    Oct 2012
    Cheers Rob ill give it a go.
    Any Joy?
    Rob
    Oct 2012
    Just back from holiday so didn't want to try it while away.
    ill let you know when I get the spray cheers.
  1. Window Stuck !!
    By S3mad in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th September 2008, 12:15
  2. Front windows stuck shut - Intermittent
    By 3.2 Ju in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th December 2007, 07:26
  3. Window stuck please help ! S3
    By slinford in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th April 2006, 14:52
  4. Urgent help needed, windows stuck down!
    By AndyMac in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 22nd July 2005, 12:43
  5. window stuck unstuck
    By gregmmm in forum General Technical / How To
    Last Post: 9th June 2003, 18:05
