JMB RetrofitsEM Tuning
    Sep 2009
    worcester
    1,097
    rooflining removal
    ive owned a few audis over the years but never had to remove the rooflining before, so am just wondering how easy it is and how to go about it, anything i should be aware of inparticular? i only need access to the rear of the roof so wont be a total removal.
    reason being at some point my aerial antenna has been snapped off at some point leaving the threaded part stuck in the base, want to remove the base to see if i can tap/drill it out so i can fit a new antenna, if not i'll get a whole new unit.
    cheers
    jon
    ps its an a6 avant
    HerefordQuattro's Avatar
    Hereford
    303
    not done it myself but can see what it says in elsawin if you like?
    A6 Avant 2.5tdi Quattro Sport 220bhp 458Nm 6 speed Manual
    wesmaster's Avatar
    Apr 2012
    Oxfordshire
    291
    Quote Originally Posted by HerefordQuattro View Post
    I need to remove mine in the summer, roof needs repainting and I want to remove roof bars for a proper job.
    Sep 2009
    worcester
    1,097
    Yeah if you could please mate, failing that i'll just have a bash and see what happens haha
    Mar 2012
    237
    You should be able to access the roof aerial through the rear load area light fitting....saves a lot of hassle and the linings never go back as nature intended....
    Sep 2009
    worcester
    1,097
    good stuff typhoon, cheers bud!!
  1. removal of small wing side indicators?..
    By rockstar in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th May 2008, 11:35
  2. Quick Help! Number plate removal!
    By mramage in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th February 2003, 21:17
  3. Rear Bumper Removal
    By Jon in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th February 2003, 13:10
  4. Removing key stereo power off
    By mramage in forum In-Car Entertainment
    Last Post: 24th January 2003, 13:46
  5. Rear side panel removal ?
    By vwchico in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th January 2003, 07:43
