Sky InsuranceChris Nott
    Feb 2013
    Allroad 2.5 V6 TDI - Won't start after Fuel Filter change?
    I did everything by the book and yet it doesn't start at all, sometimes it does, but very rarely and the engine sounds rough.
    I fulled the filter with fuel prior to installment so I'm unsure of where the error was.
    How do I bleed the system properly? - I don't have any suction vacs so it's a litle hard. Any ideas?
    Thanks.
    Mar 2012
    244
    Wont work unless its vacuum bled......
    You need to power the tank pump at the fuse box.
    My way is at....
    Audi A6 Avant - Refurb & Repair (Pic heavy) - Page 24 - Detailing World
    Post #238
    Some earlier models require a the filter to be clamped off according to ElasWin
    Feb 2013
    I managed to do it, it seems my whole problem with starting is that the intake pipe on the turbo has come off. The previous owners had use primitive tape to keep it connected and through the knocks, pushes and bangs of changing the fuel filter, I must've knocked it off; which is turn stopped the car from starting and/or prevented it from revving to clear our the air bubbles.
    Many thanks for the help.
  1. Audi A3 2.0 TDI won't start
    By johal87 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th April 2014, 13:11
  2. Bike won't start after using NOS **Epic thread**
    By andyb_88 in forum General Chat
    Last Post: 30th January 2012, 23:19
  3. 2.5 tdi will not start after edc rebuilt
    By 106pete in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 21st August 2011, 14:23
  4. Car won't start after taking out the instrument CLUSTER HELP!!!!
    By Gsai in forum VCDS (formerly VAG-COM) forum
    Last Post: 27th March 2011, 18:48
  5. Replies: 1
    Last Post: 15th February 2009, 19:59
