AH FabricationsChris Nott
    audi-a6's Avatar
    Aug 2011
    christchurch
    489
    2.7t boost problem
    Not sure if turbo('s) have gone or i got boost leak, have not tested for leaks yet as just so busy. boost used to hold 1.3 with lots of power, but now struggles to hit 0.8 even when it does in 3rd gear or above it dips down to 0.4 and wont come back up until i reset ecu or just restart engine only code i get is 17964 negative deviation or boost limit not reached..... iv attached 2 videos 1 is just mainly so you can hear the noise the turbos are making the other is the same but 3rd gear run with boost cutting down to 0.4.....
    Boost 1 - YouTube
    Boost test - YouTube
    Boost 2 - YouTube
    Passat B5.5 tdi....... big plans to come
    Audi A3 8p motor way work horse
    Nissan Skyline r33 gts-t ..... my mid life crisis fun car
    myth's Avatar
    Dec 2012
    117
    There are only 3 things that can cause that kind of error code:
    1.broken hose(s)
    2.vanes on the turbo are clogged/stuck
    3.solenoid valve for boost pressure control (N75) defective
    First thing first, is to do a boost test.Then you should change the N75(if you can, with a friend's) and if the problem is still there, it's the turbo(s).
    From my personal experience, when the vanes on the turbo are stuck, it causes a positive deviation, so in your case I think it's the N75 actuator faulty.
    audi-a6's Avatar
    Aug 2011
    christchurch
    489
    okay, i know at the same time this started to happen a rubber seal off of the intake pipe mysteriously disappeared .... that makes me think the turbos.......
    myth's Avatar
    Dec 2012
    117
    If you have a intake pipe seal missing, then you don't need to look any further.
    Seal missing=boost leak=negative deviation.
    audi-a6's Avatar
    Aug 2011
    christchurch
    489
    Quote Originally Posted by myth View Post
    no, this is only the rubber ring that seals the intake pipe to the maf housing, is still sealed with out it, my pointy is that i think the ring went into the turbo, i dont think its a boost leak, as even when i first pull away gentley you can hear the turbos giving a deep howl?
  1. boost problems
    By mac1403 in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th December 2005, 17:16
  2. MOVED: S3 Boost Problem
    By bampy in forum The Welcome Section
    Last Post: 30th May 2004, 23:04
  3. Boost Problems!!!! New Owner So Quite Worried!!!
    By Add7 in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th May 2004, 12:50
  4. boost problems - following remap
    By tim99 in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th May 2004, 12:59
  5. S3 Boost problem
    By Mike.M in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st March 2004, 23:13
