Chris NottBadger5
    Dec 2010
    Wellington, Somerset
    102
    2.5 v6tdi starter motor problem
    THis morning car would not turn over, after wiggilling key & gear selector leverl (auutomatic) it started, it did this twice. Since then its been turning over fine each time but the starter motor continues to run after the engine has started. I can even turn off the ignition and remove the key and the starter motor is still running even though the engine stops. This stops after 20s or so. No fault codes showing. Any ideas on where to look to find the problem?
    wesmaster's Avatar
    Apr 2012
    Oxfordshire
    291
    Quote Originally Posted by ms1083 View Post
    Id say due to the fact that you have to wiggle a bit, probably ignition switch. Otherwise solenoid on starter goosed.
  1. Battery/starter motor problem
    By Jakey90 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th March 2012, 17:46
  2. A3 won't start - starter motor problems
    By Allygal in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th October 2011, 17:49
  3. Help!Starter motor problem?
    By paul_e88 in forum General Technical / How To
    Last Post: 24th February 2011, 14:19
  4. Starter motor problems?
    By shamrock in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th January 2011, 14:53
  5. Starter motor problem?
    By imported_Daren_28 in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th December 2004, 13:39
