Volks AutosAH Fabrications
Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By TYphoon GB
Thread: Timing belt time to change where to buy
    Jul 2011
    50
    I need to change the timing belt as the mileage is now around 70000 it's a 2004 a6 Allroad can anyone recommend a supplier and what all do I need to change.
    Mar 2012
    244
    Belts Continental or Gates get both belts.
    Get the kit with all bearings, bolts and tensioners.
    Thermostat from Audi
    Water Pump KWP or Doltz
    Timing Tools
    Remove Front end
    Lock crank and injection pump
    Remove everything on the front
    Remove vacuum pump and cover
    Clean up
    Fit new parts
    Do Timing
    Refit front end
    Done!
    Actually slightly more difficult...
    Eric Ash likes this.
    Oct 2008
    Rochester
    16
    Or,
    Find independent garage, get a quote for cambelt kit, all aux belts, rollers & tensioners, water pump and thermostat, using Audi parts.
    Go Audi and price match
    Got all mine done for just less than a grand, the parts alone are around 600.
    Regards
    Mark
    Jul 2007
    London
    3,238
    Quote Originally Posted by Bansheemax View Post
    Or,
    Regards
    Mark
    Or give me 500 quid and i will supply and fit Contitech full cambelt/injector pump kit which includes vibration damper, KWP water pump, genuine thermostat + seal, 5L of antifreeze, 2 drivebelts and electronic timing of the injector pump ! I am based in N. London and my mobile number is all over the internet ! Google it !!!
    FOR SALE:
    Sep 2008
    London
    50
    Hi all
    I drive a TT Mk2 got my cambelt, water pump and timing belt all audi parts all in for £370 and I am aslo based in N London.
    If you want to get yours done just message me and I will give you the contact information
    I now have MSS Kits Springs on my car
    The ride quality is far superior than OME and many other brands that I have tried
    Mar 2012
    244
    Having done this recently I'd take adamss24 offer!
    Jul 2011
    50
    Thanks for all the advise on this I am based in N Ireland so it leaves it a bit tricky , adamss24 what is your supply only price for the parts ?
    Jul 2007
    London
    3,238
    Quote Originally Posted by overdraft View Post
    I will need a reg number as parts differ slightly but as a rough quote about £370-400 for parts. Beware that audi repair kit (timing belt kit) does not include the vibration damper which is £120 on it's own from dealer. Also job takes 6.5 to 8 hours and it's quite involved- would not attempt doing it you have no previous experience + you need the right locking tools- no mark and pray job on these as i've seen a few with dropped valves due to messed up timing jobs ! Most times is a new head,rod, piston, injector + the engine needs taking off the car which is not an easy job to do on a drive !
    FOR SALE:
  1. Timing belt - when to change?
    By smokeymike in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 12th May 2011, 22:46
  2. Timing Belt frequecy of change ? every 40k miles ?
    By imported_roydonaldson in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd April 2010, 19:07
  3. Timing belt + Water pump change
    By RICH2JOSH in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th April 2009, 14:07
  4. Timing belt time......
    By calbeaver in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th February 2008, 21:30
  5. A3 1.8TS - Should water pump be changed with timing belt?
    By SMc in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th May 2007, 11:36
