Sky InsuranceBadger5
    Jul 2011
    50
    Another air suspension question
    Our a6 Allroad late 2004 seems to have a mind off its own in regards to its suspension it can go for days retaining its height setting then others days its dropped almost to its bump stops on the front.
    it will flash the warning light for the suspension on start up and eventually return to setting two,is there setting on turning off the ignition that drops the height or something .
    any help would be welcomed.
    Oct 2008
    Rochester
    16
    Chances are you have a leak in one of the suspension airbags.
    Is it any particular corner?
    The reason I ask, is that the NSF is the most common to go first.
    Jul 2011
    50
    Quote Originally Posted by Bansheemax View Post
    I have heard air coming from the the front passenger side after stopping one day , but then the car would remain in the height setting two for a few days In a row. I thought if there was an air leak it would be continuous
    Oct 2008
    Rochester
    16
    Not always, mine would be OK on LV3, but if left on 1 or 2, would start to sink after 5mins.
    The best way to check, is to spray on some soapy water, they usually go towards the bottom of the bag, as they roll under.
    Check at each level.
    If you can here air and see bubbles, it's shot, replace ASAP, because the hole will get bigger, and place extra strain on the compressor.
    Replace with Arnotts, Gen1 or 2, the choice is yours.
    I would also replace the other side, as this will not be far behind in failing.
    Regards
    Mark
    Jul 2011
    50
    today the suspension wont return to its level at all.the front passenger air bag seems damaged.
    before i start ordering new air bags its was flashing the orange symbol on the instrument clusher, now its solid no flashing.
    before i order new bags is it a electronic failure or part failure can anyone advise please?
  1. Another S3 suspension question
    By mohsin1315 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th November 2012, 11:22
  2. Another Air Con Question.
    By benjie in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 10th November 2011, 21:19
  3. another suspension question!
    By btmotorsport in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th August 2008, 22:02
  4. Sorry another suspension question!
    By d18ony in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th May 2008, 16:35
  5. Another suspension question
    By S3 AD in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd April 2007, 21:24
