EM TuningChris Nott
    Sep 2012
    45
    A6 C5 Avant fog lights
    Hi, yesterday i had a light come up on the dash and it appears to be telling me theres a lamp gone on the car, there are what i think are 2 fog lamps next to the number plate but only 1 is working, any ideas how i get to this bulb to change it? thanks.
    wesmaster's Avatar
    Apr 2012
    Oxfordshire
    291
    Quote Originally Posted by Keggers View Post
    Hi, I think only 1 is supposed to work, not 100% sure. Never checked. Will look later and post reply.
    Sep 2011
    Scotland
    124
    Yep only 1 rear fog light on them. Double check all your other lamps.
    Normally the warning light will come on when the lights are first used so if you turn the sidelights on first and the warning comes on the fault lies there.
    If you push the brake pedal and the warning comes on then a brake light will be faulty and the same applies for your headlights so just try them all one at a time.
    Sep 2012
    45
    Thanks, yes it looks like theres no lamp in both, have just started car and as soon as i put the brakes on it triggers the alarm for the light fault, both lights are working in the main light clusters but there is a slight flickering in the brake light bar over the back door! could this cause the faulkt light to register and if so how do i remove it to rectify the probem, are these lights a row of bulbs or do i need to replace a complete unit? thanks
  1. A3 fog lights on pre 2001 model
    By imported_RonX in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th August 2004, 15:19
  2. Need new fog light!
    By justin_1ss in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th June 2004, 19:50
  3. rear fog light
    By sllt1776 in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th January 2004, 00:45
  4. A4 fog lights fit on an S4???
    By qtip123 in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th November 2003, 14:19
  5. Lame O Fog lights
    By banjo_guru in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 12th September 2003, 18:04
