Badger5Volks Autos
    Sep 2012
    LEEDS
    125
    water jet lines to rear in an avant
    can anybody on here tell me where to locate the water jet lines to the rear i and a6 avant c5 please .
    I have looked along the sills in side the car but to no avail.
    Thanks in advance
    Oct 2012
    106
    It is taped into the wiring loom along the inside
    of the sill on passenger side under the carpet. It's
    a corrugated black plastic line. It has joins under the
    dash, under rear footwell, and in boot above the
    toolkit, all of which can pop off causing big leaks.
    If that's your prob I glued all the joins with epoxy
    resin and they're now fine. It can also split where
    the loom enters the tailgate and can pop off the
    back of the wiper motor inside tailgate. Mine has
    done all of the above!
    vorsprung bloody technical error...
    2001 A6 1.9tdi SE Avant
    Sep 2012
    LEEDS
    125
    I am sure mine is alright its wet at the tailgate so think mine as all the tailgate cover is soaking wet .
    took it off last night to have a look and was soaked as all the water was still dripping out .
    You would think audi as a company would sort out menial design faults eg wash system and plenum chamber problems before production ?
    Oct 2012
    106
    Yep, some dodgy design there, only seems to cause probs
    At higher mileages by which time many of audis original customers
    have moved onto their next car so I guess they're
    not bothered by issues affecting folk trying to keep 10yr old mega mile cars with several prev owners on the road.
    The line tends to snap inside the rubber bung on the right
    Where it enters tailgate next to the hinge in case you want
    to check. Mine had had a previous repair with a piece of
    rubber hose, best if luck sorting it!
  1. Rear Windscreen wiper stuttery/water jet not working-any ideas?
    By jnielow in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th November 2012, 12:50
  2. Water leak in rear of a4 avant
    By nickf in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 26th June 2011, 10:14
  3. Rear winscreen Water jet problem
    By rhubarb4 in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th April 2008, 18:26
  4. fitting PI rear spoiler to avant ??
    By DodgeT in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 22nd September 2006, 17:04
