EM TuningChris Nott
Results 1 to 36 of 36
    myth's Avatar
    Dec 2012
    91
    Cold starting problems: 2.5tdi AFB
    Hello everyone!
    I have bought an Audi A6 2 weeks ago,which I'm very proud of, but now I'm seeking help with my cold starting problems.
    The engine is 2.5TDI engine code AFB, it has 286000 km on board (with the camshafts replaced at 217000 km, for those who are wondering). A few days ago I personally changed the timing belts and the thermostat. This is how the timing looks like now http://i48.tinypic.com/2luswu1.jpg . I think it's pretty good I also verified all the glow plugs.
    The problem with starting first time in the morning is that it takes 5-8 seconds of turning the engine until it starts up. After the engine is warmish, it starts pretty damn well.
    Today I did a little experiment, at -2 degrees celsius: started the engine(took around 6 seconds, after the glow plug light went off). After 30 seconds of running, I switched off the engine and started it again. I started in like 1 second! Switched off the engine and tried again in half an hour: at least 5 seconds of turning the engine...
    For a side note, I use 15W-40 Mobil Oil and no fault codes appear using vag-com.
    What else can I verify to solve this annoying problem? You guys are the last hope before going to a damn service!
    Jul 2007
    London
    3,089
    Where abouts are you based ? Far from N. London ?
    FOR SALE:
    myth's Avatar
    Dec 2012
    91
    I'm way farther than that. About 1300 miles away I live in Romania.
    Mar 2012
    227
    If all else is well at that mileage I would chuck a can or two of diesel flush additive in a tank of fuel.
    If it starts and runs live with it?
    I'm guessing the injection pump cold advance could be shot (worn springs) or a bit of corrosion from watery diesel.
    Check Measuring Block 08 Channel 4 to see if timing is within spec. I understand the Pump duty advance should be less than 10%.
    The VP44 pump is a Big Ticket Price item! (new or recon)
    myth's Avatar
    Dec 2012
    91
    http://i46.tinypic.com/2guwdas.jpg here it is. What do you think?
    Also, can you describe in details what you've done here? :
    Timing the 2.5 TDI - A few questions.
    Anyways, thanks for showing interest in helping me
    Just wanted to add that after the engine is on, it works really well. The engine pulls really hard under hard acceleration, the mpg is around 28, which is OK for these temperatures.
    Mar 2012
    227
    Numbers look OK to my eye but an expert may be along later.
    Here is the plastic valve that can cause issues.
    [IMG]http://i266.photobucket.com/albums/i...g/P1030828.jpg</a>[img]
    Mar 2012
    227
    Just checked mine again and on Basic Settings 004
    835 RPM Late 2.8 ATDC 100% Cold Start
    Not sure if that helps...
    myth's Avatar
    Dec 2012
    91
    I'm not sure how to "read" that cold start valve percentage...
    I replaced that plastic tee valve but the starting didn't improved.
    I recorded the starting of the engine this morning at -8degrees Celsius,because a video is worth a thousand pictures, here 2.5tdi AFB cold start - YouTube
    Mar 2012
    227
    I put money on fuel delivery.... doesn't help I know.
    Did you try a diesel additive/cleaner?
    myth's Avatar
    Dec 2012
    91
    No, I didn't tried any additive. I'm skeptical about them. Do you have any recommendation? Maybe I should check the injectors...
    Mar 2012
    227
    I use Millers Diesel Ecomax but basically anything with cetane on it/in it. Raises the combustion 'quality' and being solvent based should clean some muck out if there is any.
    As it seems to be fuel then...
    Pump in Tank (doesn't do much)
    Filter (easy swap but would affect all running conditions IMHO)
    Tube (air or fuel leak)
    Return valve (you did that)
    Diesel Injection Pump (does everything and has a poor record)
    Injectors (conditioner should highlight that)
    Anyone else?
    myth's Avatar
    Dec 2012
    91
    So, I used Metabond Megasel and the starting hasn't improved. Now, I guess, I should take down the injectors and put them on a test bench.
    audi-a6's Avatar
    Aug 2011
    christchurch
    487
    i know its a diesel and mines a petrol, but i had the exact same problem, turned out to be the temp sensor. before you start for the first time when cold, just unplug the temp sensor and try and start, if fires up right away then thats your problem....
    Audi a6 2.7 bi-turbo, spax coilovers, 3SDM 19" 10j alloys, full turbo back twin exhaust with RS6 style exits, HID's, DRL's, over sized RS6 spoiler, stage 2 remap, RS4 K&N, Infinity 6x9, infinity door speakers, orion hcca 15 in custom enclosure 1 x hifonics brx2000.1 amp and 2 x hifonics brx 640.4 amps, 2 x yellow top batterys, RS4 turbos, inlet pipes, stage 2 clutch
    myth's Avatar
    Dec 2012
    91
    Hi there
    Usually, when the temperature sensor is faulty, it gives an fault code when scanning but mine didn't show any fault codes.
    I tried unplugging the temperature sensor and gave it a try. It started even worse.
    Mar 2012
    227
    If it was injectors it would be all the time would it not?
    Cold start cycle seems the problem only leaves fuel feed, pump cold advance, gplugs and EGR does it not.....?
    Stumped!
    Sorry
    Mar 2012
    227
    Hey....
    Try this
    Ignition on wait for glow light to go off.
    Turn off ignition and repeat 2-3 times
    Then try a start .....
    If it works then Glow Time control module needs a tweak (no not sure how)
    From a BMW owner that one...
    myth's Avatar
    Dec 2012
    91
    The glow plugs have a maximum time of running of 10-13 seconds (it says in the "manual" when you purchase one) so letting them run 20 seconds or more chances are that you will burn them.
    This morning the car sat in the garrage where the ambiental temperature is around 7 degrees, while the outside was -5 to 0 degrees for the last few weeks and the car started waaaaay better, but not as I was expected.
    What buffles be is that when I start the engine for 10 seconds, shut if off and then start it again, is starting like the engine is warm! My theory is that at least one of the injectors is leaking(example:holding only 90 bar instead of 300 over the night) and once they are "filled" again with diesel, the injection pump doesn't have to build up the pressure again.
    My next goal is to get the injectors out and replace the diuses, but the current problem is money. It will cost me around 140 pounds.Excluding labor, cause that is done myself.
    TwistedMind's Avatar
    Long Live The A6
    Jan 2011
    115
    Easy answer, but make sure you are using winter diesel
    Audi A6 1.9TDI 2000
    Love the problems !
    myth's Avatar
    Dec 2012
    91
    It is possible to start difficult if I'm not using winter diesel? I really never thought of that.
    Long Live The A6
    Jan 2011
    115
    Yes Winter diesel has antifreeze additives.
    Audi A6 1.9TDI 2000
    Love the problems !
    myth's Avatar
    Dec 2012
    91
    So, I tried winter diesel and no result. Its still starting hard when cold.
    audi-a6's Avatar
    Aug 2011
    christchurch
    487
    if car started worse when you unplugged the temp sensor, surley thats a sign as if it was fine it should of started the same
    HerefordQuattro's Avatar
    Hereford
    303
    Have you double checked there is no air in the feed from filter to VP44 Pump?
    Only ask as i changed my filter and T-valve last year and stil had some air bubling about, after a starting problem earlier in the week i changed the filter for a better quality one (o-ring was better fit to T-valve) and now have zero air bubbles and better starting.
    Your prob could be a combo of weak glow plugs, cold weather and air bubbles = hard starting.
    just a thought
    A6 Avant 2.5tdi Quattro Sport 220bhp 458Nm 6 speed Manual
    myth's Avatar
    Dec 2012
    91
    I finally found the cause!
    After a routine check, I found that the oil level was higher than normal. Since antifreeze level hasn't dropped, it could only be diesel. So I took off the injectors.
    The injector nozzle has 5 spray jets. 5 of the injectors had only 4 jets going well, 1 jet of each nozzle was clogged.They were spraying diesel at 210-220 bar. Even that, they were not THAT bad...
    One of the nozzle barely had 2 jets working, under heavy load, but on light load it was "pissing" diesel instead of spraying. This one could only keep a pressure of 150 bar.
    That's why the engine needed a lot of turning, so the injection pump could build up the pressure again, so the 5 other injectors could spray diesel into the cylinders.
    With a price of 67 euros per nozzle in Romania, I searched the net. I finally ordered a set of 6 nozzles from Germany with a staggering 133 euros per set. They are on the way and will keep you updated when the new nozzles are in place.
    May 2012
    25
    I'm having the exact same problem with my 2.5 tdi a4 mine has the ake engine I fear that ur problem is not going to go away with the new nozzles on the injectors as I've replaced my injectors completely and made no difference whatsoever I have heard that the diesel lines can crack and leak the tiniest bit which allows air into the system while not being driven! I had the car up on a lift last week and noticed diesel at the bottom of the bulkhead on the right hand side I couldn't see where it was coming from tho there's a section where the diesel lines are covered has anyone else ever heard of this there appears to be a bit of stripping involved to access the lines
    wesmaster's Avatar
    Apr 2012
    Oxfordshire
    279
    Quote Originally Posted by myth View Post
    Not 100% true, its not a CR engine so if 1 injector is faulty the other will still work. I would say you have found a fault, but wait and see when you have fitted new injectors.
  28. #27
    myth's Avatar
    Dec 2012
    91
    I'm back with updates. The engine starts way better with new nozzles, but it doesn't start ... suddenly, it starts few cylinders at a time, just like some glow plugs are faulty. I rechecked them, they are all fine, but I noticed that some of the glow plugs connectors are not in perfect condition. Some of them make that click noise when you connect the glow plug, some doesn't. I believe that those connectors that doesn't click may be the cause of the rough start.
    I can also note that the engine pulls way better than before
    But now I have another problem: Out of 20 engine starts, 2 were very long and different than usual, so I checked for errors and I get one fault code:
    01268 - Quantity adjuster (N146) -intermittent.
    I believe that N146 is part of the injection pump and I'm worried about this fault code.
  29. #28
    myth's Avatar
    Dec 2012
    91
    So I got the problem solved
    The problem of that fault code, and the hard start(cold and hot) was caused only by the pressure valve located on top of the injection pump, as shown here Biodiesel Myths: Diagnosing TDI Performance Issues (Part 2) - YouTube
    I must note that I changed the valve. In the video it shows that you can tap the tip to get back to position. Once it's out of position, I think the valve is faulty.
    I also replaced the glow plugs connectors and now the engine starts like a charm in the morning.
  30. #29
    Jun 2011
    Great Melton Norfolk
    1,340
    Glad you got it sorted.
  31. #30
    Jul 2007
    London
    3,089
    Only trouble is the valve on top of the VP44 pump is not like the valve on the VP37, the v6 tdi valve has a cage mounted to retain the guts of the crank relief valve. I suspect the seal was faulty hence the hard starts from cold ! I have a similar b5 audi with a tiptronic gearbox which exhibits similar cold starts but it's fine from hot ! The fuel runs back into the tank if left nose up on hill but will start instantly when parked nose down. It's my missus runabout and i will break it for spares soon. I noticed the previous owners fitted non return valves on feed and return hoses but still no wiser. It's got better once i have replaced the fuel filter and plastic tee valve to genuine Hengst/VAG parts...
    FOR SALE:
  32. #31
    myth's Avatar
    Dec 2012
    91
    I should add that I mounted a valve from a VP37 on my VP44 (without that cage). Keep us updated once you replace some parts for your problem.
  33. #32
    Jul 2007
    London
    3,089
    And why would you do that for ? VP44 pump runs higher case pressures than the vp37 will ever do ? You better swap it for the old one, just replace the seal...
    FOR SALE:
  34. #33
    myth's Avatar
    Dec 2012
    91
    What are the difference of pressures these pumps work?
    It doesn't matter seal that much. The thing that is faulty is that little rod inside it. If it is out like in this picture http://img.photobucket.com/albums/v3...2/2011-4-3.jpg it's faulty. I cannot order a new valve from the shop because they only order an entire pump, so for that matter, I took one from a scrap pump.
  35. #34
    Jul 2007
    London
    3,089
    Trust me mate, the seal is the problem in your case, the valve you have will spill the guts much quicker than the vp44 valve will. Look for keystone mod on tdi forum, might be able to save some grief later on !
    FOR SALE:
  36. #35
    Mar 2013
    Sheffield
    10
    Not sure if this has been said. I had a 2.5 Tdi with cold start problem. I used 2 stroke oil in the diesel. not the expensive stuff the cheap stuff is better. when i topped up. after a few miles. it got rid of the cold start problem. i think it was a fuel delivery issue air getting sucked in. but the 2 stroke fixed the cold start problem. and not only that it made my car a lot smoother.
    the oil will also lube up and keep your fuel pump and full fuel system in good nick. some forums will tell you that it makes your car better on fuel , i didnt se any change in mpg but my car did run a hell of a lot smoother.
  37. #36
    myth's Avatar
    Dec 2012
    91
    @vag_man, I checked what you said and I tried myself with a combination of 1:200. That's 300ml for 70l of diesel. I don't know if the cold start has improved or not(it starts well anyway), but the engine runs better, at least at idle. It vibrates less,as I can notice the gear lever shakes less at idle.
    Before the 2T oil, I had a sqeak at idle, no matter what the condition were. If I accelerate at ~1000 rpm, the sqeak disappeared. Now, after I put the oil into diesel, that sqeaking noise disappears after the engine is warm. At 90 degrees C, I never hear that sqeaking noise.
  1. 2004 2.5tdi Cold Starting Problem
    By 76rossco in forum Diesel forum
    Last Post: 19th January 2010, 17:28
  2. A4 2.5tdi cold starting problem
    By Quattro john in forum Diesel forum
    Last Post: 26th July 2009, 13:09
  3. S3 Cold Start Problem
    By squale in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd November 2008, 01:15
  4. Cold start problem
    By C Mesher in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th August 2007, 15:24
  5. audi coupe 2.3 e cold start problems
    By buzby3xx in forum Classic Audi Forum
    Last Post: 27th August 2006, 23:21
