JMB RetrofitsBadger5
    Sep 2012
    LEEDS
    125
    gearbox ecu part numbers !
    I was just wondering if i bought a gearbox ecu with all the same numbers but the last two letters different would it work?
    my numbers are 4B0 927 156 DN all the letters up to the DN are correct however the ones i have seen have different letters BH on one of them. Its of the same year make and model but just wanted to make sure .
    Mar 2012
    244
    1 4B0927156D
    control unit for 5-speed automatic gearbox
    gearbox code: / ACK,ALG DEX
    (1) 4B0927156AH
    gearbox code: / AQD,APR,ATX ECD,FAV
    (1) 4B0927156CQ
    gearbox code: / AXM FAV
    (1) 4B0927156AM
    gearbox code: / APS,ARJ ECC
    (1) 4B0927156CN
    gearbox code: / ATM,ASM,AMM FAM
    (1) 4B0927156BC
    control unit for 5-speed automatic gearbox / for vehicles with electronic stabilisation program -esp-
    (1) 4B0927156C
    gearbox code: / AGA,AJG,ALF DEV
    (1) 4B0927156E
    control unit for 5-speed automatic gearbox / F >> 4B-W-170 000*
    gearbox code: / AFB DEW,ETY
    (1) 4B0927156BH
    control unit for 5-speed automatic gearbox / F 4B-W-170 001>>*
    (1) 4B0927156CD
    gearbox code: / AFB DEW,ETY,FAT
    (1) 4B0927156BR
    gearbox code: / AKE ETM
    (1) 4B0927156DN
    gearbox code: / FEF,FAU AKE
    (1) 4B0927156CG
    control unit for 5-speed automatic gearbox / F >> 4B-1-080 000*
    gearbox code: / AKN EMM,EUA,FAP, FRU
    (1) 4B0927156DL
    control unit for 5-speed automatic gearbox / F 4B-1-080 001>>*
    gearbox code: / AKN EUA,FAP
    (1) 4B0927156DH
    gearbox code: / AZA,AJK EDF,FAW
    (1) 4B0927156CC
    gearbox code: / ARE FAX
    (1) 8D0927156EG
    gearbox code: / AFB,AKN ETX
    (1) 8D0927156CM
    control unit for 5-speed automatic gearbox / for vehicles with electronic stabilisation program -esp- / FUR KD- GETRIEBETAUSCH
    (1) 4B0927156G
    gearbox code: / AGE DPT
    If that's right you may have an issue...
    Sep 2012
    LEEDS
    125
    Thanks once again typhoon .
    Had a problem with the plenum chamber flooding and the water comming into the car diverside footwell just damp but the rear one was like a swimming pool .I have dried it all out and tok the gearbox ecu out of the car opened it and left it in a bag of rice to dry last week.
    I put it back in yesterday and it seems to be behaving so hope fully problem solved .(its not slapping into gear any more )
    I have sorted the grommets out in the plenum chamber (what a joke they are ) and tested before putting it all back together .
    Checked a mates on thursday and you could have kept a goldfish in it .lol
    Left car running with the air con on for about 2 hours yeaterday and got the soundproofing quite dry will have to repeat this over the next few day .
    Mar 2012
    244
    Mine had fish (or a similar bug) swimming in it.
    Keep smelling screen wash and suspecting it full again but last clean out seems to have worked.
    All data came from VagCat boards
  1. ECU part number ? 2006 sb - Chassis No Inside
    By KemiksiZ in forum A3/S/RS Parts
    Last Post: 16th January 2012, 16:42
  2. ECU PART NUMBER
    By tdi-man in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd March 2011, 10:32
  3. Wanted ECU part number 8D0 907 558 DA For AJL Engine
    By NineNails in forum A4/S4 forum(B5 Chassis)
    Last Post: 7th February 2011, 20:05
  4. Airbag ECU part number help.
    By whitty in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 23rd July 2010, 10:29
  5. ECU part number
    By stumunro in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th February 2003, 12:49
