A few faults
Agniusss
Member
Dublin
Hi. Any help is much appreciated
VCDS Version: Release 11.11.4 (x64)
Data version: 20120807
Saturday,27,October,2012,19:56:57:26868
Chassis Type: 4B - Audi A6 C5
Scan: 01 02 03 06 08 15 16 17 18 22 34 35 36 37 45 55 56 57 65 67
75 76 77
VIN: WAUZZZ4B92N093018 Mileage: 169050km/105042miles
Address 01: Engine Labels: 06B-906-018-AWT.lbl
Part No: 4B0 906 018 DC
Component: 1.8L R4/5VT G 0001
Coding: 11502
Shop #: WSC 00499
VCID: 65CB4C3EFF093230B23
WAUZZZ4B92N093018 AUZ5Z0B0158064
No fault code found.
Readiness: 0110 1001
Address 03: ABS Brakes Labels: 4B0-614-517.lbl
Part No: 4B0 614 517 G
Component: ABS/ESP front 1728
Coding: 06275
Shop #: WSC 00000
VCID: 254B0C3EBF89F230723
Address 08: Auto HVAC Labels: 4B0-820-043-MY2.lbl
Part No: 4B0 820 043 AC
Component: A6-Klimavollautomat 0105
Coding: 00001
Shop #: WSC 02325
VCID: 5BBF6AC6C94D74C0147
1 Fault Found:
01592 - Air Quality Sensor (G238)
57-00 - Electric Circuit Failure
Address 15: Airbags Labels: 4B0-959-655-AI84.lbl
Part No: 4B0 959 655 M
Component: Airbag 8.4E 4003
Coding: 0001306
Shop #: WSC 00028 021 00000
VCID: 3A71CF4276376DC82F1
Address 17: Instruments Labels: 4B0-920-xxx-17.lbl
Part No: 4B0 920 950 K
Component: KOMBI+WEGFAHRS. M73 D02
Coding: 00844
Shop #: WSC 00000
VCID: 2A51FF02D697DD485F1
2 Faults Found:
00849 - S-contact at Ignition/Starter Switch (D)
30-10 - Open or Short to Plus - Intermittent
01336 - Data Bus for Comfort System
37-00 - Faulty
Address 35: Centr. Locks Labels: 4B0-962-258.lbl
Part No: 4B0 962 258 D
Component: Zentralverriegelung D35
Coding: 06881
Shop #: WSC 02325
4 Faults Found:
01366 - Opened Due to Crash Signal
35-00 - -
01562 - Right Rear Door
59-00 - Can't Unlock
01561 - Left Rear Door
61-10 - Won't De-Safe - Intermittent
61-00 - Won't De-Safe
End ---------------------------------------------------------------------
Thanks in advance
[h=2]01366 - Opened Due to Crash Signal[/h][h=4]Possible Causes[/h]
  • Output Test performed on Airbag Control Module (J234)
  • Vehicle involved in Accident
    • Airbag Control Module (J234) stored Crash Data
  • Wiring/Connectors from/to Airbag Control Module (J234) faulty
[h=4]Possible Solutions[/h]
  • Check/Clear Fault Codes
  • Check Wiring/Connectors from/to Airbag Control Module (J234)
[h=2]00849 - S-Contact at Ignition/Starter Switch (D)[/h][h=3]00849 - S-Contact at Ignition/Starter Switch (D): Unknown Switch Condition[/h][h=4]Possible Causes[/h]
  • Terminal 15 OK, but Terminal S not OK
  • Fuse(s) faulty
  • Wiring/Connector(s) from/to Ignition/Starter Switch (D) faulty
  • Ignition/Starter Switch (D) faulty
  • Check Terminal S
  • Check Fuse(s)
  • Check/Repair Wiring/Connector(s) from/to Ignition/Starter Switch (D)
  • Check/Replace Ignition/Starter Switch (D)
Have you cleared the faults and then rescanned?
Are you shareware, full VCDS or paid software version.
Flat battery can return random air bag, crash detection and other faults and may cause the ignition fault code.
Did you have any DIS display warnings?
Does the climate control work?
If not may be old faults that were not cleared.
I know its a pain but you could also try to clear faults in VCDS, then disconnect battery for 20 mins.
Reconnect and rescan should reboot all the ECU's etc.
Make sure you have radio code and know how to reset the clock and the windows :)
After that any fault is probably valid and you can take all your christmas money to Audi for new bits....
Yes I deleted and rescanned. I have full VCDS Ross tech. The battery is 1year old and have 5 years warranty (Bosch 780mah). No warnings. All climate control functions are working. Its not possible to delete these faults and I don't know why.? Radio is fittest not original. I fitted my self.
Crash signal should reset as a minimum.
Suggest disconnect radio and repeat ....VCDS doesn't like aftermarket radios.
I'd still pull the battery for a while as that should reset any old codes (some say 20 mins some 2 hours).
If the radio install pick up on a live rather than the bus bar (does it stay on after the ignition is turned off but key still in?) that might explain some of the faults.
No. It's starts from key ( ACC ) and off when you turn off the engine. I will try to delete all faults and don't start the engine and take out battery + let's say for two hours. I will try to do that first thing in a morning before I go to work and I will post again faults if there will be left :yes:
P.S. Thanks
Tuesday,04,December,2012,11:06:43:26868
75 76 77
VIN: WAUZZZ4B92N093018 Mileage: 170250km/105788miles
Coding: 11502
Shop #: WSC 00499
1 Fault Found:
18010 - Power Supply Terminal 30
P1602 - 35-00 - Voltage too Low
Readiness: 0110 1101
Coding: 06275
Shop #: WSC 00000
Coding: 00001
Shop #: WSC 02325
2 Faults Found:
01206 - Signal for Duration of Ignition Off Time
27-00 - Implausible Signal
Coding: 0001306
Coding: 00844
Shop #: WSC 00000
1 Fault Found:
37-10 - Faulty - Intermittent
Coding: 06881
Shop #: WSC 02325
5 Faults Found:
00668 - Supply Voltage Terminal 30
07-00 - Signal too Low
01570 - Turn-Off Delay; Terminal 15
29-10 - Short to Ground - Intermittent
60-00 - Won't Safe
Stumped!
It all points to low voltage to me....
The door faults may be linked to the Convenience Module that suffers from damp issues.
http://www.audi-sport.net/vb/a6-s6-allroad-forum-c5-chassis/92036-convenience-control-module.html
Also lube the door lock catches as they signal the faults and rely on feeble micro switches.
The air quality sensor only detects dirty air and switches to re circulation. Unless your driving in a coal mine or Chernobyl its probably useless. Some people report they go dead every 2-3 years.
Expert needed....
I have thrown hundreds of dollars and over 60 hours at solving 01366. Airbag module, CCM, door latch modules, hatch latch module, battery, wiring, dome lights, puddle lights, foot well lights, harnesses, soft coding... finally someone told me to pull out my hazard light switch. Fixed.
