EM TuningChris Nott
    Oct 2011
    West Yorkshire
    67
    1.9tdi thermostat location / guide?
    Done a search but not joy. Is there a guide to change the thermostat? I know on my old b5 it was near the oil filter underneath. Anyone know where the bleed valve is for when the system is refilled? Thanks in advance!
    Oct 2012
    101
    I did one recently on my awx 1.9 tdi, it's in a black plastic housing behind the alternator on front left of engine block, bleed hole is under battery/pollen filter cover at back of bay adj to brake servo. I used passat Haynes manual as a rough guide as its (roughly) same platform as a6 and same engine, easy job and no need to move alternator if you've got a good selection of ratchet extensions etc.
    2001 A6 1.9tdi SE Avant
    Oct 2011
    West Yorkshire
    67
    awesome thanks for the advice got it sorted today
  1. Thermostat fitting guide
    By jiggaman in forum A4/S4 forum(B5 Chassis)
    Last Post: 14th November 2009, 10:28
  2. 2.5 v6 TDI thermostat location
    By sprinter1801 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th April 2008, 03:50
  3. Thermostat location 1.8T?
    By JayB5UK in forum A4/S4 forum(B5 Chassis)
    Last Post: 25th October 2007, 15:31
  4. thermostat location?
    By Rob_k in forum A4/S4 forum(B5 Chassis)
    Last Post: 25th July 2007, 13:31
  5. Thermostat location? anyone? A4 TDI
    By vw754 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 22nd February 2007, 10:09
