JMB RetrofitsVolks Autos
Results 1 to 7 of 7
    Jul 2007
    London
    3,255
    What size tyres for 20" wheels 8.5" wide ET 45 ?
    Hi, got a set of audi a8 d2 20" alloy wheels, they are 8.5" wide and thinking to fit them to a c5 audi a6 lowered on Eibach springs. I need larger wheels as i have rs4 b7 front brakes to go which won't fit behind fat5 wheels without spacers, ! I have hp2 allroad brakes fitted at the moment and they are not man enough to stop the car from high speed ! As some may remember, it's fjtwelve's old a6 with double the stock power ! I have d3 9" wheels at the moment on my c5 allroad but i run 25mm spacers to clear the uprights. What is the best tyre size that could go on 8.5" wide rims without looking too stretched. I would probably go for Michelin Pilot or Falken tyres... Thanks !
    FOR SALE:
    wesmaster's Avatar
    Apr 2012
    Oxfordshire
    291
    I'll try to find out later, maybe I can help you with tyres at wholesale prices including fitting.
    Txt me or send pm when you know what size. What size tyres you got on the 18" Fat Fives?
    What you gonna do with fat fives? Might be interested.
    Quote Originally Posted by adamss24 View Post
    Mar 2012
    244
    Jul 2007
    London
    3,255
    Quote Originally Posted by wesmaster View Post
    Thanks mate, really don't know what size will fit well without being too stretched, the Falken's i have on the allroad look a little stretched on the allroad, albeit on a 9" rim !
    FOR SALE:
    Aug 2009
    London
    45
    Perfect timing. Apologies Chris, for the thread-jack, but it's sort of related.
    I am also looking for tyres for my 20" 8.5" wide A8 wheels for my C5 allroad. Read up lots on loads rating. Currently got 225/55/17 (97Y) on stock 5 spoke rims, 2.1bar all round. Feels way too floaty.
    Hope i've got this right. So you take the kerb weight plus the average max cargo weight, divide by 4 which should give you the load rating for each tyre??? Did it the other way from Parker's Guide. Kerb weight = 1790kg. So. 97=730kg. 730x4= 2920kg. 2920-1790=1130kg. 1130/4= 282.5kg per wheel.
    Most places suggest an upgrade to 255/35/20 (101). What tyre pressures do you run?
    Dec 2012
    20
    A8 TYRES AND ALLOY WHEELS
    Quote Originally Posted by Alski2009 View Post
    CURRENTLY ARE USING 275 X 35 X 20 ON 9J AND ALL FINE AND HANDLING JUST GREAT CURRENTLY THINKING OF GOING TO 9.5J WOLFRACE RR
    evomaster3000's Avatar
    Dec 2004
    Bristol
    449
    I'm running 225/35 tyres on my 20's, my car is a tad lower and not really going for an OE look, the tyres are stretched a bit.
    The offset is ET35 which I believe is the minimum i'd say you could run. With the suspension as low as i've gone on mine then next issue is the actual arch clearance on the front, when I deck the coilovers the tyres are literally rubbing on the wing!
    I'd say if you want to run wider tyres with less stretch and more profile you'll need a lower offset to clear the front strut, then you run in to issues of arch clearance.
    Have a look at how 225/35/20 fit on an 8.5" rim on ET35 all round:
  1. 18" wheels & what size tyres
    By gradwells in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 26th April 2012, 00:52
  2. What size tyre for stretch and best choice tyre?
    By g10chy in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th January 2011, 17:42
  3. what size tyre for standard 1.8t sport A4?
    By Fraser in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th December 2010, 10:48
  4. What size tyres should i go for? 19x8.5 ET45
    By kreativeJ in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th July 2010, 16:37
  5. what size tyre on 18" wheels ??
    By batty in forum A4/S4 forum(B5 Chassis)
    Last Post: 7th July 2008, 13:03
