JMB RetrofitsVolks Autos
Results 1 to 8 of 8
    Nov 2008
    35
    Yellow warning light- Dynamic Headlight range control faulty
    First of all been on for two days now, so not going away!!
    What is this? What does it do? How do you fix it? etc etc, Is there a company on here I can visit to fix it? And how expensive is this going to be eeeeeeeekkkkkk!!!!!!!!!!!!!!!!
    Audi A6 2001 4.2 estate Quattro
    Cheers Kevin
    Apr 2012
    N. Wales, LL22
    1,224
    vcds scan needed for starters
    VCDS in North Wales
    2007 A6 3.0TDi S-Line Le Mans Avant , adaptive xenon lights, sunroof, privacy glass, towbar, led rears & randomly rear seat airbags
    1999 Honda S2000 , mcb low milage jap import, fully bushed, mugen exhaust <<< for sale! <<<
    2001 Passat TDi 130 Sport < sold!! http://img.photobucket.com/albums/v343/Ste_Nova/Passat/PB140007s.jpg
    Aug 2009
    200
    Quote Originally Posted by CO11K9 View Post
    Cheers Kevin
    To answer some of your questions. The Dynamic Range is the auto adjustment for the Xenon headlights to prevent you dazzling other drivers and the warning suggests there is a fault in that system. As suggested you need to get someone with VCDS to scan the vehicle to determine the actual fault but it is probably one of the sensors that determines the angle of the car to horizontal that has failed.
    2012 A6 Avant 2.0TDi SE
    1970 Lotus Elan +2S
    Mar 2012
    244
    Check and clean the two pin connector on each headlamp that drive the leveling motor.
    The drivers side is pain to get to but its a simple fix.
    You will need VCDS to clear the faults (headlamps on for that)
    The connector is a crap mini thing.
    Its the far connector in this rather poor pic...
    Also check the arm on the passenger side suspension that drives the control.
    Nov 2008
    35
    Cheers Guys for replying, I looked inside the passenger arch on the front suspension arm at the sensor that has a plastic arm connected to the main suspension, it had broken and come away, probably 11 years of road salt/rain etc etc so the metal nut looked rusted to death and the plastic self levelling arm bit was hanging loose,
    Is it a coincedence a couple of weeks ago I had a large load in the boot for a couple of days.................I wander if that stretched the plastic arm to its limit and snapped it off the rusted nut??????????????????????
    Mar 2012
    244
    Its more likely front lower arm bush wear transmitting vibration etc to that weedy little arm.
    Nov 2008
    35
    Typhoon GB thankyou for the pics, it is the lowest plastic arm bit that has come away and snapped off, hopefully I can get that bit for £15 rather than a whole unit for over £100!!!!!!!!!!!!!!
  1. DIS Warning - Dynamic Headlight Range
    By V8Guzzler in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th April 2011, 19:50
  2. Replies: 1
    Last Post: 31st May 2010, 10:58
  3. "Dynamic Headlight Range Control Faulty" warning on DIS
    By gcs3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th March 2010, 15:48
  4. headlight range control
    By kanievsky in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th October 2007, 15:57
  5. Dynamic headlight range control faulty
    By gav in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 18th August 2007, 07:53
