Chris NottMonster Motorsport
    Jun 2010
    Question Removing Brake Master Cylinder - Need some advice
    Hi All
    I have a 1998 Audi A6 1.9tdi , recently I found the brake pedal travels a fair amount when braking. I have narrowed it down to a possible faulty master cylinder. Picture attached is only an example.
    Can someone tell me if its possible for the MC to be unbolted and pulled out of the plenhum chamber without having to remove anything else such as the brake servo. I ask as there is very little space there for it to move and wanted to know if anyone else has done this or has an idea before I get stuck. Thks
    Mar 2012
    221
    According to Elsa Win you can do it.
    The brake pedal needs to be locked out (special tool listed) and all the lines disconnected.
    Notes about resetting brake pedal, cruise (if fitted) and bleeding whole system.
  1. Replacing the Brake Master Cylinder
    By Metro in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th April 2012, 19:01
  2. brake master cylinder
    By murdoch in forum A4/S4 forum(B5 Chassis)
    Last Post: 5th January 2012, 13:55
  3. Replacing the Brake Master Cylinder problems
    By Joe_i in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th March 2010, 18:38
  4. S3 Brake Master Cylinder upgrade
    By Barks in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd January 2010, 08:31
  5. Water under battery tray & brake master cylinder....
    By jrleech in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th May 2006, 06:18
