Badger5EM Tuning
    Nov 2008
    50
    2.8 manual problems
    Any known or common problems in a 2.8 with manual gearbox?
    Is the same box used in any other models?
    Whats the 2.8 like itself? Reliable or best to avoid?
    Mar 2012
    244
    Lasy big V6 used in A4, A8 & Passat
    All the manual boxes were pretty similar in design and avoid the auto box electronics issue.
    Problems relate to mileage and service history.
    Lots of buyers guides on the net.
    Any issues with the clutch or noisy release bearings suggest walk unless its dead cheap.
    If you can get underneath make sure there is no oil around the clutch housing as that's the drive shaft seal/bearing going bye bye.
    jcb
    Sep 2005
    uk
    4,077
    are they dual mass flywheels?
    Mar 2012
    244
    Need to check specific model but I believe they were all dual mass.
    There's single (solid) mass unit conversions out there but not cheap and some need a different slave unit.
  1. Audi A4 2.4 manual gearbox problem
    By MGTURBOM in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 6th June 2011, 20:00
  2. Audi Cabriolet - Manual Hood Problem
    By AllDubbedUp in forum Classic Audi Forum
    Last Post: 21st February 2008, 08:50
  3. Ooo eck I've got a problem!
    By AlexStanley in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th January 2003, 13:12
  4. Problems with alarm transmitter.
    By DJG in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th January 2003, 08:23
  5. A3 drivers workshop manual???
    By RichA3Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th January 2003, 21:45
