Badger5AH Fabrications
Results 1 to 8 of 8
    Oct 2012
    16
    Plenum chamber flooding
    Bit concerned about this. Was this still an issue on the 2005 allroad or had it been resolved by then?
    Oct 2012
    102
    Is yours a late C5 shape? (like the one in my sig?), if so, yes, if not, check the C6 forum.
    2001 A6 1.9tdi SE Avant
    Oct 2012
    16
    Quote Originally Posted by mrnice View Post
    It's a 2005 C5
    Oct 2012
    102
    In that case yes, it's an issue, the main thing is to unblock the two drain holes under the battery and brake servo, a search on here (or even google should find you some info on how, it's a quick and easy job!
    Mar 2012
    244
    Something (to check) for the Weekend?
    Seems most people remove the rubber grommets so it never happens again...
    Oct 2012
    16
    Quote Originally Posted by TYphoon GB View Post
    Thanks for that I think I'll definitely be investigating this weekend. Looks like you had a lucky escape with it not entering the cabin!!
    Oct 2012
    16
    Quote Originally Posted by mor48 View Post
    Tried and failed!!
    Couldn't get the f£&@king battery out. It simply was to large to get out, the only option I could see would be to remove the windscreen wiper arms and the plastic moulding at the base of the windscreen. But this seems hugely over complicated for such a mundane task as changing a battery!!!!
    Oct 2012
    102
    I know it looks tricky but it is possible to wiggle the battery out If you (very carefully)
    move the wiring harness out of the way (it goes right across the front bullkhead of
    the plenum chamber and says 'do not bend' on it).
    The rest is easy, the battery tray has to come out to really clean out the guck!
    A previous mechanic/bodger had already cut down the rubber grommets on mine
    so I left them as is.
  1. Plenum Chamber Drain Grommets - Every A4 B6 owner is affected by this common fault
    By pj123 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 11th July 2012, 21:04
  2. Allroad Plenum Chamber
    By steveliddle in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 4th June 2012, 15:11
  3. Allroad Plenum Chamber
    By steveliddle in forum The Welcome Section
    Last Post: 1st June 2012, 11:21
  4. Plenum chamber bungs
    By Rhencullen1989 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 28th July 2011, 07:20
  5. Audi A6 C5 - check your plenum chamber - mine was full of water
    By Alski2009 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 23rd January 2011, 00:34
