JMB RetrofitsChris Nott
Results 1 to 7 of 7
Thread: Help please
    Oct 2012
    16
    Help please
    Hi All,
    I'm hoping for some advice. On Wednesday morning i'm going to look at a 2.5TDI Allroad, 2005 with 45,000 miles and the automatic gearbox.
    It has full service history and seems in good overall cosmetic condition.
    I would hugely appreciate advice on what to look out for beofre buying it.
    I've done a little research and am lead to believe potential areas of concern are the air suspension and the gearbox, so in particular any tell tale things to look out for on these would be fantastic.
    Many thanks!
    Oct 2012
    16
    Also it has 225/55/R17 wheels and I would want to put Hankook Optimo 4S tyres on it. They don't come in that size though, nearest is 225/60/17" would these be ok to fit.
    Thanks.
    Mar 2012
    244
    Cambelt and water pump replaced?
    Gearbox oil serviced?
    State of front control arms?
    State of Cv Boots?
    Rust round inside of arches?
    Undercovers in place?
    Vag Com code scan for any faults?
    60 profile tyres will upset the speedo calibration slightly not ideal on an auto and also your insurance company if they ever have to notice them...
    Oct 2012
    16
    Thanks for the info, I understand the speedo thing but why would 60 profile be more of an issue on an auto?
    Mar 2012
    244
    Quote Originally Posted by mor48 View Post
    The gear box mechatronic takes inputs and feeds several systems such as the ABS and Traction. It expects inputs that match e.g engine speed, road speed, ABS etc unlike a manual that just does what you tell it.
    Whilst the ratio difference is slight its software and may make the 'wrong' judgement as to what gear and when or that reading means I should activate stability control or just throw a 'I dont understand' code error.
    You insurance company may be interested as (apart from looking for any excuse not to pay up) it 'could' affect the ABS and traction in an 'emergency' and would class as 'modified' from the manufacturers specification.
    Some of the latest VAG's cars for example have winter tyre settings so the software can better cope with conditions against expected behaviour.
    In reality it may make little difference as the A6 C5 had a range of tyre sizes, profiles and rims through its life. Speed and load ratings are of course the real issues.
    Mar 2012
    244
    Just as I am playing with a new Wheel/Tyre calculator...
    55 60
    Diameter
    679.3mm 701.8mm
    Circumference 2134.1mm 2204.8mm
    Speedo error 0% -3.21%
    Reading at 30mph 30mph 29.04mph
    Reading at 60mph 60mph 58.08mph
    Ride height gain 0mm 11.25mm
    Arch gap loss 0mm 11.25mm
    So thats technically over the 10% allowed in law for speedo error.
    Sep 2011
    Scotland
    124
    Tire Size Comparison
    Specification 225/55-17 225/60-17
    Sidewall 4.9in 5.3in
    Radius 13.4in 13.8in
    Diameter 26.7in 27.6in
    Circumference 84.0in 86.8in
    Revs/Mile 754 730
    Difference 0.0% 3.3%
    Back to the Calculator
    Copyright 1996-2001, Eunos Communications LLC
    That will be fine as the difference is only 3.3%, but one thing to bear in mind is that even with the right size of tyre I doubt your speedo will be bang on.
  1. help please!!!! audi 5000 problems needing hep
    By grantk in forum Classic Audi Forum
    Last Post: 5th May 2004, 01:32
  2. Some help please New A3 TDi or 3.2
    By Wish in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th November 2003, 17:03
  3. URGENT Help Please
    By [Dave B] in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th November 2003, 17:06
  4. Help please.
    By c_coffell64 in forum Classic Audi Forum
    Last Post: 18th June 2003, 00:50
  5. I.T. help please!
    By MisterD in forum General Chat
    Last Post: 20th January 2003, 21:19
