    Oct 2012
    Allroad semi auto prob
    Bought a 2004 allroad 3 wks ago and have been happy with it.
    The problem is that this morning driving to work the semi auto mode would not activate.
    Had to drive in full auto and that seemed to over rev on take off. Stopped after 5 miles and restarted car and all seemed fine.
    Also in full auto the display was not showing what drive mode i was in s....d....r......n.....p for example.
    Would like some feedback as the car is still under warranty.
    It's a 2.5tdi 2004.
    Mar 2012
    227
    The box is driven by a mechatronic unit immersed in the oil.
    These suffer from 'dry joints' and solenoid failures.
    A Vag Com scan should show any faults.
    First off check date of last box oil and filter change. Many people get a return to normal after a oil change.
    Otherwise its a new module (about £2K) or a rework by ECU Testing (about £500 including a local independant fitting as the oil is £100 on its own).
    Audi A4 A6 PRNDS light flashing - Audi Faults
    If you do get a vag com error then ECU will test the device for about £40 to £50.
    If there are no errors this may not prove the unit is good but start looking at the wiring and the external sensors feeding the box.
    Good luck killed 2 on my DSG TT luckily all on warranty!!
    Oct 2012
    Thanks mate I'll get it scanned.
    Dec 2010
    Wellington, Somerset
    101
    Def get it diagnosed whilst under warranty, i have had to have a new gearbox = very expensive.
    Another issues it may be, which is quite a lot cheaper, but still would be diagnosable by reading fault codes is the selector lever. Inside the unit there is a circuit board which can fail. Mine is tempremental, worse on cold damp mornings. It means the car's electronics is unable to know which gear you have selected. Apparantly this normally happens few years after someone drops a drink over the area and the electronics start to corrode.
    ALso, the selector mechanism contains little magnets which move across the circuit board, again to identify which setting is selected, these magnets can drop out of their carrier meaning however much you move the lever the electronics are unaware of your choice. This probablly won't get picked up by fault scanning but easy to check & fix yourself.
    Oct 2012
    Going to get scanned
    make contact with the garage and they say they will call me when they have arranged a courtesy car.The car has a few issues I want looked at.With it having a short warranty(three months) I want this done ASAP.Thanks for your input.
  1. Semi Auto Audi A4 Cab - Gearbox Dieing
    By chris101 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 13th October 2011, 22:35
  2. 'Slipping' Auto gearbox 2.5TDi Allroad?
    By toadusmodus in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 13th March 2011, 13:45
  3. Advice on buying Allroad 2.7T AUTO
    By silverstealth in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 11th August 2009, 11:31
  4. Auto tiptronic / computer prob
    By dengsx in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 11th April 2007, 23:01
  5. semi auto
    By kevlibstt in forum General Chat
    Last Post: 7th January 2007, 13:32
