Monster MotorsportChris Nott
Results 1 to 11 of 11
    Oct 2012
    106
    removing and replacing steering wheel pitfalls
    Car: 2001 a6 1.9tdi se avant
    Hi folks,
    I've recently replaced both track rod ends and had tracking done. For the drivers side tre I gave it to a mechanic having run out of time to persuade the damn pinch bolt to move. I got the car back with the front wheels pointing in very different directions (alarm bells...), and traction control obviously having fits. I took it elsewhere to get 4 wheel tracking done but the mechanic doing the tracking said he could get all the wheels pointing the same way but couldn't get the steering wheel straight. It is sitting a few degrees to the left with the wheels sitting straight.
    For a while after this the traction control would turn itself off randomly and i got a fault code-
    1 Fault Found:
    00778 - Steering Angle Sensor (G85)
    27 - 10 - Implausible Signal - Intermittent
    Then, after I replaced the front discs and pads (one pad of which was actually worn down to the sensor wire), the traction control problem disappeared.
    My question is-
    The steering wheel being off centre is irritating me. Can I remove it and adjust it by a few degrees without having to mess with the steering angle sensor in vcds? (I only have vcds lite and old vag-com (both unregistered) to work with).
    I've been searching the interweb for a while for answers but not come up with anything definitive yet.
    Any thoughts most appreciated!
    2001 A6 1.9tdi SE Avant
    Jun 2011
    Great Melton Norfolk
    1,349
    you can set the steering wheel straight yourself no problem,if you just want the wheel straight.
    HerefordQuattro's Avatar
    Hereford
    303
    Similar post only a few days ago, can't understand why wheel alignment specialists can't get wheel straight.
    All they've got to do is lock the wheel straight ahead then wind the TRE's in or out to set the toe???
    simples
    A6 Avant 2.5tdi Quattro Sport 220bhp 458Nm 6 speed Manual
    Oct 2012
    106
    Quote Originally Posted by HerefordQuattro View Post
    simples
    thats what I would've thought, and thanks Heinz, I'll just whip it off, stick it back on and hope for the best
    Hereford
    303
    you can't set the wheel straight by taking it of and hoping the next spline will line up it's got to be done by TRE adjusment, i'd take it to a alignment specailist who knows what they're doing
    Jun 2011
    1,349
    i just set my wheel slightly o.ff ,so the spoke is lower towards the window, Makes it more comfortable when using door armrest
    Lancaster
    1,780
    Seeing as it used to be straight and the sensor was set when it was straight. You should be fine just aligning it.
    To do: None yet.
    Oct 2012
    106
    Quote Originally Posted by BlackQuat View Post
    thanks, this is more or less what I thought, though I haven't had the wheel off yet, only the airbag (to find I didn't have the right torx socket), I'll give it a to and report back..
    jcb
    Sep 2005
    uk
    4,077
    sure you can.
    done it mine without issue.
    they garage set the tracking and it was off by a miniscule amount which annoyed me.
    if it is anything like mine it has 20 odd spline so one spline is still a goodly amount of angle but depending on how much you are out you could be lucky
    Oct 2012
    106
    Ok, so my original post prob didn't explain the question too well,
    I'd not had the steering wheel off before and from some random
    threads I'd mistakenly gathered that as you take the wheel off the
    Contact ring thing that the steering angle sensor is attached to would pop out
    and cause some sort of computery wizard farts.
    ...And that I might need to set steering angle to zero in vcds (or some such
    hassle).
    i wasn't at all worried about moving the wheel round a few splines.
    Anyhow, finally got a few spare minutes to do it- moved it a few splines counterclockwise and
    now it sits fine and is no longer annoying me
    Apr 2012
    N. Wales, LL22
    1,224
    just to add.... if the wheel hasn't been taken off, don't take it off to make adjustments
    VCDS in North Wales
    2007 A6 3.0TDi S-Line Le Mans Avant , adaptive xenon lights, sunroof, privacy glass, towbar, led rears & randomly rear seat airbags
    1999 Honda S2000 , mcb low milage jap import, fully bushed, mugen exhaust <<< for sale! <<<
    2001 Passat TDi 130 Sport < sold!! http://img.photobucket.com/albums/v343/Ste_Nova/Passat/PB140007s.jpg
  1. How to remove and replace A3 (2004) o/s headlight bulb?
    By Reedswood in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th October 2013, 11:28
  2. Clearout: Audio, S3 brakes, A3 install and A4 steering wheel
    By Shane. in forum For Sale/Wanted - Audi Parts
    Last Post: 5th September 2011, 23:13
  3. remove and replace n/s rear speaker grill...
    By tullA6 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 16th April 2011, 20:51
  4. Replacement Steering Wheel Badge
    By d4mo in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th June 2009, 22:41
  5. Removal of the steering wheel on a an a6
    By maxlbrown in forum General Technical / How To
    Last Post: 11th April 2007, 10:42
