Sky InsuranceBadger5
    Mar 2012
    244
    Can you get replacement front hub bushes....
    Seems the inadvertently came out with the ball joints.
    Got two mangled ones so can't pop em back in.
    Its the bits that should stay in the hub...but are sized on...
    Anyone?
    HerefordQuattro's Avatar
    Hereford
    303
    Bit confused to what you mean mate, that pic is a lower arm, but there is no 'bushing' i know of just the machined taper in the hub that the ball joint fits into?
    A6 Avant 2.5tdi Quattro Sport 220bhp 458Nm 6 speed Manual
    Mar 2012
    244
    Ahhh but the pics doesn't show the taper. The bit over the taper is the soft metal bush from the hub that the ball joint sits in!
    Here's where the bushing should be...
    Had to lift a set from another hub and press em back in.
    Oh and no one does replacements.... a market for a self lub bush that makes removal easier me thinks.
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,523
    Yep part of the upright only. Common for them to stick sadly
    Hereford
    303
    Glad they stayed in when i did mine then, that would have been the final straw "fetch the petrol and matches please love"
  1. Can you get adjustable or shortend front drop links for S3?
    By VTI_EG_DAN in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st May 2009, 17:48
  2. can you get the led lights for the s3?
    By edward_harris in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th April 2007, 10:29
  3. Can you get a MF wheel fittewd to a05 A4??
    By skooby in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 2nd November 2006, 09:07
  4. Can you convert from front wheel to 4wd??
    By kano in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th March 2004, 06:27
  5. Can you get tuning boxes for SAME tractors??
    By smanning in forum Diesel forum
    Last Post: 17th July 2003, 09:55
