AH FabricationsSky Insurance
Like Tree1Likes
  • 1 Post By wesmaster
Thread: Number plate lights not working
    TwistedMind's Avatar
    Long Live The A6
    Jan 2011
    115
    Lightbulb Number plate lights not working
    Hi all, new problem
    My number plate lights have stopped working. Lamps are ok and there is no voltage at the terminals.
    Do the wires connect back to the rear lights, or are the on a seperate circuit ?
    Help, before i get pulled !!
    Audi A6 1.9TDI 2000
    Love the problems !
    wesmaster's Avatar
    Apr 2012
    Oxfordshire
    276
    I would start looking at the wiring when the boot shuts, normally breaks there, open close open close and so on.....
    Also check the earth is good.
    TwistedMind likes this.
    Long Live The A6
    Jan 2011
    115
    Webmaster, thanks for the time. Saved me alot of greef.
    I jiggled the cables from the boot lid to the car, and yes number plates were like a disco !!
    How do i repair ? Do i split the rubber and resolder ? Then just use tape to reseal ?
    Just worrid about water ingress.
    Mind
    Audi A6 1.9TDI 2000
    Love the problems !
    wesmaster's Avatar
    Apr 2012
    Oxfordshire
    276
    release rubber boot and peel back, solder, heatshrink and done. Can be tricky if the rubber boot wont peel back, get a helper.
    Good luck!
    Dec 2010
    Wellington, Somerset
    100
    I had similar problem but it was the tube supplying the rear washer that cracked in this joint, caused water to trickle in both directions causing very annoying water stain around rear boot light and soaking inside of boot trim. Easy to repair but bit fiddilly, especially working out which bits of trim pull off, in which order and where the hidden screws are.
    Long Live The A6
    Jan 2011
    115
    Split the rubber open, 2 broken wires and the rest broken down to bare copper. Re soldered and fixed.
    Thanks for all the help. Be lost without this forum !!!
    Mind.
    Audi A6 1.9TDI 2000
    Love the problems !
  1. audi A6 q 98 number plate light not working
    By MADEIRA in forum General Technical / How To
    Last Post: 7th April 2012, 21:39
  2. Number plate lights not working, any ideas?
    By Rastamouse in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 9th March 2012, 10:23
  3. Another 'help number plate lights not working' thread!
    By Daws88 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd March 2011, 08:14
  4. Number Plate Lights not working!!!
    By mdre83 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th April 2010, 18:22
  5. UK reg 54 plate 2.4 V6 rear number plate lights not working - CAN Bus issue?
    By A6fella in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 9th December 2008, 14:29
