Sky InsuranceChris Nott
    Aug 2012
    2002 A6 3.0 V6 Quattro Sport (petrol) - advice on this car??
    I've found a very nice V6 Quattro - 2002 - 3.0 220 bhp - immaculate with 99,000.
    Can anyone out there advise on this model and this engine?
    Pros/cons/gotchas... ?
    I am aware that this will be a hungry beast - not too concerned tbh - just need to know if its a reliable good running vehicle from someone with 1st hand experience.
    Aug 2012
    Ok - looked at the V6 with my brother (Mechanic of 20 some years) - amazingly good ocndition but with a busy oil leak at the front more or less below the crank - my brother has said the following:
    * Likely a blown crank shaft seal or cam seal if further up.
    * Car drives perfectly - no loss of power or response ( just oil :-)
    * No unwelcome noises or knocks
    * Suggested a strip out of front end and replace all obvious seals plus a new timing belt and maybe even water pump also.
    The guy selling it will part with the vehicle for £1000 - my brother will do the work for zero in the evenings - I'm only out the parts.
    Thoughts on this from the more technical folk on here?
  1. Buying a used A3 3.2 Quattro Sport - any advice?
    By liy6ml1 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th September 2007, 17:27
  2. Good exhuast for 2002 1.8 T Quattro Sport?
    By Cossie_boy in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th May 2007, 13:15
