    Mar 2012
    244
    Something (to check) for the Weekend?
    Had a new windscreen fitted today after a lump of flint said hi and the stone chips all joined up.
    Guy fitting it finished and said even though hes not a mechanic or Audi expert this looked wrong...
    Had a look and found my A6 had its very own aquarium....
    Seems the drain holes are blocked.....those that followed the rebuild will know that the last owner wasn't into cleaning...
    Removed the battery and found a nice pool....complete with wildlife...
    If you having a look I moved the loom instead of stripping the windscreen (again) so take note..
    Couldn't see the drain so started to drain the water by suction...
    Found the first drain and pushed out half a forest...
    Car then wet itself...
    Found the other drain under the servo...
    Again blocked solid with foliage.
    Clean up and plenty of maintenance spray
    Then refit everything...
    So suggest those of you in the wilds take a quick peek!
    Have a good weekend.. :-)
    TwistedMind's Avatar
    Long Live The A6
    Jan 2011
    115
    This is a well known problem on here. Total ****e design by audi. I just compleatly removed the rubber bungs. Nice big hole for the water now.
    nice job on the pics !
    Audi A6 1.9TDI 2000
    Love the problems !
    Oct 2012
    106
    Me too on this, cut the bungs down so they're less able to clog, my first few months of ownership consisted of this sort of preventative bodgery.
  1. Something for the Weekend
    By stoakseya4 in forum RS6 Forum
    Last Post: 4th January 2010, 22:37
  2. Something for the Weekend
    By stoakseya4 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 4th January 2010, 01:01
  3. Something for the Weekend
    By stoakseya4 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 3rd January 2010, 18:45
  4. Something for the Weekend
    By stoakseya4 in forum RS4 Forum (B5 and B7 Chassis)
    Last Post: 3rd January 2010, 12:02
  5. Something for the Weekend
    By stoakseya4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd January 2010, 11:44
