Badger5Sky Insurance
Results 1 to 12 of 12
    HerefordQuattro's Avatar
    Hereford
    303
    Question A6 C5 Steering Rack leak
    Evening girls and boys,
    Had a bit of a groan coming from steering for last few weeks which i thought was worn ball joints etc but turns out it's a power steering leak.
    Noise was horendous and steering heavy so topped up with mineral oil which fixed it until i took it for a spin and noticed the oil pouring out of the N/S track rod end boot!
    The outer end of boot has split and come away from the clip but I pressume this was just disguising the leak from within, the only place this oil could be coming from is the end of rack seal... yes??
    If so is it possible to change these seals? with the rack in situ?
    If it's a replacement rack job are there any recomendations for sourcing part (new / recon) and any tips for removal fitting? (i have elsawin distructions)
    cheers chaps
    Jake
    A6 Avant 2.5tdi Quattro Sport 220bhp 458Nm 6 speed Manual
    Aug 2009
    London
    45
    Gutted
    Gutted to hear your steering rack needs changing. Although i haven't changed this on my C5, having spoken to people who have, this is a nightmare job.
    Some poor fella is facing the same hardships on Audizine Steering Rack 3rd Bolt (from underneath)?
    Hereford
    303
    Quote Originally Posted by Alski2009 View Post
    I know it's going to be a tough job but i'm more worried about the price, Audi quoted me £777 retail and £637 to me!!!!!!!
    Hereford
    303
    Anyone know if it's possible to just replace the seals???
    Hereford
    303
    Rack out what a job!!!! all in about 8 hours spread out over the weekend.
    Totaly destroyed the N/S heat shield getting to the last bolt so going to have to bodge some exhaust wrap round the cat/turbo pipe as no way i can get the shield back on (it's fubar)
    Local factor can get a recon rack in for £250 exchange but it's an "XL" anyone had dealings with this brand?
    Hereford
    303
    the plot thickens, ordered the reman rack from local partco and it turned up the next day but was the wrong one (5 options against my chassis number!) anyway the 1 i actually need isn't available so they're sending my rack away to be reman'd and should get ti back in 5-8 days!
    Good job My mum's in spain for 6 weeks and i've got her car to get by.
    Decided to do all the front control arms while it's off the road and up in the air and will need aligning after anyway, wish me luck
    Mar 2012
    244
    Luck Wished.......luxury of A6 ownership.....new windscreen today (£75).... and a water issue I will post shortly...
    Any pics of the rack removal?
    Just in case you know...MoT in 2 weeks...
    Hereford
    303
    Taken a few pics and will try and post up if i get time, ps it's a tw#t of a job to do ;-)
    brasiliangringo's Avatar
    Mar 2010
    544
    Whats the part number of your rack ?! I may have one.
    Hereford
    303
    OE number is 4B2 422 066E later superseded by 4B2 422 052 FX according to the audi parts man.
    Koyo/SMI rack with intergarted steering damper (no external damper bracket), it's off being remanufactured hopefully as not heard anything back...
    Hereford
    303
    Angry
    FFS got the reman rack back today and it looks like my original rack but some tool has put an external damper bracket on the end and i won't know why till the morning.
    And i wish i'd never started the control arm job, that fecking top pinch bolt is an absolute NIGHTMARE, the drivers side came out with just a few big taps with a drift but the O/S is now locked solid it may as well be welded in, i've tried SDS drill, propane torch, lump hammer and the SOB ain't coming out.
    May have to take the bloody upright off to get it out - is it possible to remove driveshaft nut withought wheel on? (i.e just using brakes and supporting knuckle on a jack?
    Mar 2012
    244
    Might help....
    AudiWorld Tech Articles
    We are cursed.......lower control arm x 2 .....ah well only money....
  1. steering rack leaking hydrolic fluid
    By deburgh999 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th September 2011, 14:26
  2. Steering rack leak
    By Ardz83 in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th July 2011, 12:15
  3. i have a leaking steering rack from a S3....
    By colicabcadam in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st October 2010, 00:42
  4. Steering rack leak
    By rossbrownlee in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd September 2009, 21:12
  5. Possible Leaking Steering Rack A4 2.6 Quattro
    By RICHARDJC in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th March 2005, 11:40
