    Sep 2012
    2.5TDi Strange Warm Starting Problem
    Hi. I'm new to the forum and would appreciate any suggestions as to how to fix a strange problem with our 97,000 mile 03 A6 Avant Sport 2.5Tdi.
    If start from cold then do a short journey (say less than 5 minutes), when I come to start it again, it will not rev beyond ~1200 rpm – doesn't respond to the throttle at all. Lots of black smoke/neat diesel on the road out of the exhausts. If I leave it running it will slowly sort itself out as it gets warm. Completely reproducible.
    Cold start or hot starts are absolutely fine and it runs perfectly. Problem is much reduced when the weather's hot.
    This has been going on for at least a year, with the annoying workaround being to never do really short journeys,.
    The local Audi indie is stumped/disinterested, having replaced the EGR to no effect.
    I'd be very grateful for any ideas about what it might be.
    Thanks in advance.
    Jul 2007
    London
    3,240
    Where are you based ?
    FOR SALE:
  1. 1.8t avant warm start problems help!
    By Mark L in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 7th September 2013, 14:24
  2. Audi A6 Estate 2.5TDI 2000reg intermittent start problems
    By Khi in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 30th July 2010, 13:31
  3. warm starting problem
    By emjim09 in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th June 2009, 21:38
  4. 1998 S4 warm starting problem? HELP!
    By myfirsts4 in forum General Technical / How To
    Last Post: 15th July 2007, 11:19
  5. 1.9 tdi (1997) warm start problem
    By markf497 in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th September 2006, 17:20
