Volks AutosSky Insurance
Results 1 to 8 of 8
    Dec 2005
    london
    196
    noise from hazard switch when indicating
    hi guys
    I have an a6 4.2 quattro 1999. When I indicate right only the side repeater lights up (doesn't blink) and no other lights come on. Also there is a noise that comes from the hazard switch. I bought a new hazard switch on ebay as I thought that was the solution but it does the same thing.
    Anyone got any ideas what this fault is and how to fix it? The left indicator works as normal
    any pointers or help would be greatly appreciated as my mot is due soon
    thanks
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,655
    All your bulbs OK?
    could be the stalk.
    my first thought would be the relay as well.
    A4 B5 Double Din, RNS-d, TMC, Full Sports Leather Heated with Leather Door Cards and Lower Door trims all for sale.
    Audrey's Build Thread
    RIP Audrey. She's being broken down.
    New Car, New Thread.
    Scott's Akoya Silver A8
    Dec 2005
    london
    196
    yes the bulbs are ok, is it an easy enough to change the stalk? I assume this is my best route?
    thanks
    Oct 2009
    Preston
    87
    Before you change the stalk try a little wd40 on the contact ring on the column and go full lock each way a couple of times to clean up the ring - it gets dirt on it.
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,655
    Quote Originally Posted by shufti View Post
    thanks
    I think its your only option now.
    The stalk is not to bad.
    Loads of little screws and springs that just want to pop out and hide in your carpet never to be found until that one day you walk through with bar feet and BANG!!!!
    Its in your foot!!
    Remove the wheel, remove the stalk and start taking the screws out. I'm not sure how the A6 comes apart but since its about the same year as my B5 I assume it would be the same or at least.
    When you pull it apart, go slow or the internals will jump about and go all over the place.
    Don't forget to clean the metal contacts and re-grease.
    Dec 2005
    london
    196
    thanks, I'll try and hunt down a stalk on ebay and give that a bash, hopefully that will get to the bottom of this..... I'll post up my results. I'll try the wd40 trick first
    Dec 2005
    london
    196
    yeah it was the stalk, thanks for you advice
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,655
    Brilliant.
  1. BKD Noise From Engine Chamber When Stationary
    By SAiLO in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th February 2013, 19:01
  2. grining noise from wheels when they spin!?!
    By JB_A3_Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th August 2011, 18:45
  3. Strange grinding/vibrating noise from rear wheels when turning!!??
    By SamiG in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd April 2010, 11:38
  4. Strange noise from rear brakes.... When driving..?
    By Rafkoo in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th September 2009, 13:03
  5. Noise from S3 when I first move forward.
    By Mike.M in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th May 2004, 15:03
