Volks AutosEM Tuning
    wesmaster's Avatar
    Apr 2012
    Oxfordshire
    291
    Noise from n/s/f and decat
    Hi all, I've had an annoying noise from the front of my 2001 2.5 tdi for ages.
    Driving me up the wall, no play in any joints, nothing worn.
    Was running out of ideas, decided to take glove box out, glad I did! The noise was the fan in its bearing, had axial play. So chuffed to find it!
    Also, decided to decat it, results are a bit more responsive, bit of smoke on heavy acceleration but not noisier!
    Will see how mpg is affected, was getting 42-50 depending on journey.
    Cheers.
    Wes
    Sep 2012
    Wiltshire
    15
    Hi Im just about to knock my cat out on my 1999 advent 2.5 tdi as it has been feeling under powered since I got it.
    after reading some chat on here I took my inlet manifold off, boy im glad I did,
    it was full of horrid sticky soot lots of it too.
    so I have a feeling the cat will be the same.
    fingers crossed this will give me some power back..
  1. Noise from rear at speed and/or high revs
    By tom barker in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th July 2012, 21:56
  2. Funny noises from the engine bay and maybe something draining the battery.
    By danpayneuk in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th August 2010, 11:08
  3. Scraping Noise from rear? Brake and pad replacement? or stone stuck?
    By parin in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th June 2009, 19:29
  4. Rattleing noise from left and back of car
    By pwnorman in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th February 2004, 21:06
  5. Nocking noise from left and rear of car
    Last Post: 10th February 2004, 20:59
